Question about CE blocks
Old Sep 16, 2008 | 04:42 PM
tomd70's Avatar
tomd70
Default Question about CE blocks
My early 70 has a 73 dated CE replacement block. Would that be considered a suitable replacement? I know nothing beats the original but I had heard that correctly dated CE blocks do not lower the value of the car substancially. Any thoughts? Thanks,Tom
Old Sep 16, 2008 | 05:06 PM
Roughrider's Avatar
Roughrider
There's a lot of variables. How original is the car otherwise? That could make a difference to some people. Is the replacement block equivalent to the original...same horsepower and torque ratings? Besides the block, are all the other parts such as heads, intake, carb, etc., the originals?
In essence, if it doesn't make a difference to you, that's all that matters.
Old Sep 16, 2008 | 05:46 PM
Mike Ward's Avatar
Mike Ward
CE block were supplied for many years as over the counter replacements to anybody, not just as warranty replacement engines.
That means your engine could have been installed by anybody at any time without it being a direct replacement for the original. Your engine could have spent it's first go around in life under the hood of a delivery truck. Without proof of the engine's provenance, most buyers will consider it as equivalent to a NOM car.
Whoever has told you that this has little impact on value is probably not aware of the foregoing.
Old Sep 16, 2008 | 09:04 PM
Drizzle's Avatar
Drizzle
and if you have a CE3***** motor (the 3 means 1973) then you most certainly have a lower compression engine with lower HP than in 70.
I have a CE0 (1970) motor in mine and as far as value, I assume that it is less than a number matching engine, but ain't no use in crying about it now. I have what I have. You could go through the trouble of changing the heads to get more performance and raise the compression to get it "like original." Personally, I'm keeping mine like it is.
To Question about CE blocks
