Rochester or Holley
Old Jan 6, 2002 | 07:38 PM
Armstrong's Avatar
Armstrong
Default Rochester or Holley
What's your preference and why? Don't want to start a fight :boxing but am looking to buy and need to make a good informed choice. :)
Old Jan 6, 2002 | 08:12 PM
68shark's Avatar
68shark
Default Re: Rochester or Holley (Armstrong)
I won't pretend to be any expert, but you will probably get better advice if you provide full info on your engine, mods, intended use. I've been amazed at how double pumpers with mech. secondaries, can be perfect for one application and not at all appropriate for another similar displacement engine.
Old Jan 6, 2002 | 08:39 PM
Steve Straus's Avatar
Steve Straus
If your car is an '81 you may not have much of a choice. I believe 81's had a computer controlled rochester.
Otherwise, it's a function of what you know how to deal with and how your engine is set up. If you are running bone stock, I'd say stick with the quadra-jet. If I were running an aftermarket intake and had some performance mods, I'd run a Holley 650 DP. I've always found Holley's to be easier to deal with than quadrajets. They are a much simpler design and are cake to rebuild, re-jet, and tune, but they can be finicky sometimes.
If you know more about rochesters than use it. A Carter AFB is also an excellent carb. I just rebuilt the one on my 61 Buick last week. Edelbrock makes a pretty good (and popular) knock-off of the Carter design too.
Old Jan 6, 2002 | 09:03 PM
mountainshark76's Avatar
mountainshark76
stick with the q-jet unless you have enough engine mods to jutify the rest of
the changes needed to run a holley ie. spacer/adaptor. linkage, kick down , fuel line and filter. try an earlier model q-jet a non fead back type, but then you may need to change distributers since your does not have a vacume advance. thats my 2 cents :cheers:
Old Jan 7, 2002 | 08:10 AM
V8yunkie's Avatar
V8yunkie
I would prefer the Q-jet most definitely. Admittedly, it is a little more sophisticated than the Holley but that also is the reason why it has a much better gas mileage and throttle response. However it can be tuned as well as a HOLLEY - if need be.
I installed one on my 72: Better throttle response, 25% less gas consumption an better cold starting characteristics.
The Holley is a muscle-car carb which was designed for easy tuning on the track - but fuel consumption never was an aspect those days.
Old Jan 7, 2002 | 08:39 AM
SteveG75's Avatar
SteveG75
Default Re: Rochester or Holley (V8yunkie)
I agree with Yunkie. Dyno 2000 says I got 335 HP with mods and I know I get 18-20 mpg with my Q-Jet. Just takes a little longer to tweak than a Holley but definetely worth it (Thanks to Lars. :yesnod: )
Old Jan 7, 2002 | 10:58 AM
Armstrong's Avatar
Armstrong
I kinda knew it but had to confirm. Q-jet it is and thanx to all replies
Old Jan 7, 2002 | 12:31 PM
Wendell Allen's Avatar
Wendell Allen
I had the same question in regards to our '72, but for economic reasons I decided to stick with the QJ. And I'm glad I did.
Check out Lar's papers on Corvettefaq.com on how to tune it properly. And the factory service manual will help on setting the idle mixture if it's been messed with.
My QJ's been more of a chore to set up than the Holley's I've done in the past, but it's proven to be every bit as good of a street carb now that I've gone through it.
Old Jan 7, 2002 | 04:02 PM
The Dude's Avatar
The Dude
Quadrajets are really terrific carbs. When they're properly tuned they can give you good mileage, snappy throttle response and great performance. There's a wealth of information out there about tuning them and dilaing them in and you won't have to have a huge assortment of parts around to mess with while tuning.
That having been said, the more I learn about and fool around with Holleys the more I like them. I've found them to be more responsive to tuning and somewhat easier to set up once you get them in the ballpark. But, the ballpark on the Holleys seems to be smaller--you either have them dead-on right or dead-on wrong.
Your mileage will probably vary. But I don't think you'll go too far wrong with either choice.
[Modified by The Dude, 12:04 PM 1/7/2002]
To Rochester or Holley
