3/8" Coolant Sensor fix
Old Sep 17, 2008 | 01:00 PM
weez58's Avatar
weez58
Default 3/8" Coolant Sensor fix
My Dart Pro 1's came with 3/8" pipe threads for the coolant sensors. After having no luck finding a compatible sensor I gave up. Then I noticed that Eddie70(thanks for the idea!) had modified one to fit his LS1 conversion. So I gave it a shot. It was a piece of cake to turn it down and rethread it for 3/8 pipe. Here's a pic. This shot is of the idiot light sender, but the guage sender turned out just a good. I know others have the same issue so I thought I'd share this solution.
Old Sep 17, 2008 | 01:10 PM
Durango_Boy's Avatar
Durango_Boy
Very cool. Obviously it's easy to try and modify a $12 part, so if you screw up you are only down $12, but do you think as a process it was easier than drilling the head and tapping it for the larger thread?
Old Sep 17, 2008 | 01:52 PM
weez58's Avatar
weez58
Not with the motor in the car. I won't say it can't be done, but it wouldn't be fun. Had I realized this before putting it in the car, I would have drilled the heads and tapped them. Also, I didn't think it would be a big deal finding a compatible sensor. Go figure...
Old Sep 17, 2008 | 02:17 PM
JimT's Avatar
JimT
Bubba fixed mine with a water pipe reducer.
Old Sep 18, 2008 | 06:35 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
: :Nice job. But for those of us that aren't machinists, how do you "turn it down"?
Thx for posting,
cardo0
Old Sep 18, 2008 | 06:57 PM
weez58's Avatar
weez58
Buy the nearest machinist a 6-pack of a good micro-brew
To 3/8" Coolant Sensor fix
