Sidedraft Crossram
Old Sep 22, 2008 | 12:49 PM
82Red's Avatar
82Red
Default Sidedraft Crossram
Does anyone here know anything about these? Advantage/disadvantages?
Old Sep 22, 2008 | 01:12 PM
Wrencher's Avatar
Wrencher
There's a guy on tthis forum that has that setup. I put one on a SB Ford for a guy with a Cobra, and It flowed a ton. he had to jet it way down to make it work, but it fit under the hood. Not sure about the clearance on a vette, looks too tall...
Hans
Old Sep 22, 2008 | 01:13 PM
V-Twin's Avatar
V-Twin
ram82fire has one.
The only disadvantage I can think of is tuning...oh and cost
Check the attached pic here:
http://www.vettemod.com/forum/showpo...2&postcount=44
Old Sep 22, 2008 | 01:23 PM
lvrpool32's Avatar
lvrpool32
You cant use tall valve covers with the crossram, thats why I went with the downdraft version.
Nick
Old Sep 22, 2008 | 03:05 PM
Belgian1979vette's Avatar
Belgian1979vette
With these setups it's getting expensive and I believe the runners on the moon intake were pretty small (not out of experience) I went with the DC&O EFI crossram setup (not completed !). With all the necessary hardware, it gets a pretty expensive setup. An Australian friend I got to know on this forum has got the DC&O working on his C4. Even with a stock engine it seems to really be worth it according to him.
Oh yeah, you cannot use a HEI with them.
Old Sep 22, 2008 | 03:34 PM
V-Twin's Avatar
V-Twin
Sure you can use a HEI, just use a small cap hei w/ et. coil.
Old Sep 22, 2008 | 04:17 PM
Belgian1979vette
I hope that means ext coil, I assume that would be possible. I myself used a electronic controlled dizzy with external coil. It was the only thing that would fit and even that one is really close
Old Sep 22, 2008 | 04:37 PM
CoolRidge69Vette's Avatar
CoolRidge69Vette
It looks pretty cool. Clearance-wise it'll fit in any Vette....as long as you don't have a phobia of using a cutoff wheel to cut a nice hole in your hood.
Old Sep 22, 2008 | 05:13 PM
Belgian1979vette
Mine fits without cutting the hood, not even by far a clearance problem. I don't think the moon has a problem either.
Old Sep 22, 2008 | 05:21 PM
V-Twin's Avatar
V-Twin
It even fits under an 82 hood with the entire air box in place.
My brother has a similar setup under his hood and he lowered the entire body and birdcage onto the frame (no body mounts) and it still fits (L88 hood).
To Sidedraft Crossram
