Best Headlight actuator seal boots?
Old Sep 22, 2008 | 07:04 PM
BIGJIM13's Avatar
BIGJIM13
Default Best Headlight actuator seal boots?
Ok
who has had luck with Headlight actuator seal boots?
the last two I have bought from different sources have torn in just a few openings....so who is the best vendor to get the boots from?
Old Sep 22, 2008 | 08:56 PM
DC3's Avatar
DC3
Both of mine are bad too. Hopefully someone on the forum will know where to source a quality replacement.
DC
Old Sep 22, 2008 | 09:13 PM
jetnoise's Avatar
jetnoise
maybe you could share where you got yours from so we avoid that source
Old Sep 22, 2008 | 09:27 PM
...Roger...'s Avatar
...Roger...
have bought them from most vendors and never had a torn one yet.Are you getting them in some kind of bind? (I always silicone them so the shaft slides easy.)
Old Sep 22, 2008 | 09:51 PM
BIGJIM13's Avatar
BIGJIM13
thought the shaft just moved the boot up and down..the grove on the shaft stops the boot from moving across the shaft
Old Sep 22, 2008 | 09:53 PM
BIGJIM13's Avatar
BIGJIM13
not sure how they would bind...pretty simple install
Old Sep 22, 2008 | 10:25 PM
...Roger...
Thats probably where I dont install it per directions.I silicone the shaft and the groove and the boot itself.If the boot wants to it can come out of the groove but will slip back in on the opposite movement.
I've seen the joint bind and fail to rotate when the rod goes in and out which forces the shaft to one side.
Old Sep 23, 2008 | 07:40 AM
BIGJIM13's Avatar
BIGJIM13
Old Sep 23, 2008 | 12:54 PM
C3 4ME's Avatar
C3 4ME
I got my seal kit from Zip. It was installed over a year ago, and still doing fine.
Old Sep 23, 2008 | 01:37 PM
BenUK's Avatar
BenUK
I've bought a pair from Ecklers and they both failed within a month. Ecklers replaced them FOC and the replacements failed too.
The ones from MidAmerica have been more reliable.
Old Sep 23, 2008 | 02:25 PM
Solid LT1's Avatar
Solid LT1
Can you say "Hencho en China?" more quality from our good friends
Old Sep 23, 2008 | 03:58 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I got my set from Zip several years ago. They seem to still be holding up well. Hopefully Zip is still using the same supplier as they did when I got mine.
Old Sep 23, 2008 | 04:25 PM
Mike Ward's Avatar
Mike Ward
Any of the boots will fail in short order if not lubricated lightly where the rubber slides over itself.
Been there done that.
Old Sep 27, 2008 | 05:09 PM
BIGJIM13's Avatar
BIGJIM13
you say lubricated lightly - with what?
Old Sep 27, 2008 | 09:22 PM
Mike Ward's Avatar
Mike Ward
I use silicone grease- 11 years and counting, no failures.
To Best Headlight actuator seal boots?
