Ive been looking into the corvette central true dual exhaust and headers for an 82 and have not heard much about it here before. Does anyone know if there is any true gain from it? I need an exhaust eaither way just if im buying new i may as well get something good.
I haven't used this system, but it looks pretty good IMO. You should be able to notice an improvement in performance and sound. I'd go with the 2.5" system. Be aware that you will be removing your catalytic converters and that could cause issues getting it through inspection -- depends on the emissions requirements for your city/county/state.
Also, on the '82 I think there is an O2 sensor that may require having a bung welded into the header. So I don't think it's going to be cut-and-dry install for you, but doable. Hopefully someone with more experience on the '82 wil chime in . . .
