rear steel spring
Old Sep 24, 2008 | 01:39 PM
Belgian1979vette's Avatar
Belgian1979vette
Default rear steel spring
I have the 7-leaf spring from VBP with the longer bolts, but the car only sits at what seems to be the normal height with the nut on the bolts at the end of the bolt.
I'm assuming that the arch in the spring is to big. Is there some way to de-arch it a little ?
Old Sep 24, 2008 | 05:44 PM
MN-Brent's Avatar
MN-Brent
7 leaf is the HD spring. I cant recall the rating, but I dont think your going to de-arch anything there.
You can buy 8 inch or 10 inch extended bolts. If you have the 8inch, go get the 10 inch to lower further, just watch out for tire sidewall clearance.
B...
KevinK's Avatar
KevinK
I would say remove one of the leafs, but that just doesn't seem like good advice.
I would call VBP, and ask them. They were pretty helpful with all of my questions.
To rear steel spring
