Lower radiator hose spring
Old Sep 24, 2008 | 05:35 PM
'75's Avatar
'75
Default Lower radiator hose spring
I have read threads of the lower rad hose having a spring to keep it from colapsing. I'm guessing that could be a hi rpm issue. My hose doesn't have one and neither does the new napa hose. I don't know that I have had this problem, but thought I would make sure it has one before i put it together. Where do you buy the hose that has it, or is it not required for '75 with L48 ? I called the chevy dealer and he doesn't have the hose and doesn't know if it comes with the spring. Any help ?
Old Sep 24, 2008 | 07:57 PM
stock76's Avatar
stock76
Every replacement hose I have bought did not come with the spring. I have just reused the original.
There must be a vendor out there somewhere that has it. Or maybe a radiator shop?
Old Sep 24, 2008 | 08:03 PM
Ironcross's Avatar
Ironcross
Gates hoses are readily available at most parts stores. They do not have the spring and it`s not really necessary. The OEM factory hose did have a spring however and a real bitch to put in. I just recently replaced mine. The only issue is age on the hose as it may go soft.
Old Sep 24, 2008 | 08:10 PM
'75's Avatar
'75
I guess I should have searched the archives before starting this thread, I found many threads on the subject. Some say the new GM hose has the spring, others say no. Seems none of the regular parts store hoses has it. Dewitts has it, Zip has it, but not Ecklers. All the parts stores say that modern hoses do not need it because the rubber is better. I think I will order it and have it on hand if I have problems with the hose colapsing. I plan to go with electric fans and a new radiator this winter anyway. Just looking to get through the last of the driving season.
Old Sep 24, 2008 | 08:12 PM
ksbunting's Avatar
ksbunting
Go to a hardware store and buy the spring and put it in yourself.
That's what I have done over the years.
Kurt
68 Coupe
Old Sep 24, 2008 | 09:29 PM
bytor's Avatar
bytor
Another option to obtain the spring is pickup one of those universal radiator hoses. (The straight but flexible kind) Most of them have a spring in them. Thats what I did and it worked like a charm.
Old Sep 24, 2008 | 09:58 PM
BarryK's Avatar
BarryK
the better vendors should have the correct hoses with the spring in it. i'd try Paragon, Dr. ReBuild, Willcox, or DeWitts.
Old Sep 25, 2008 | 07:08 AM
tommyleea's Avatar
tommyleea
Don't know if it is true or not, but I was told that the spring was installed at the factory due to the procedure they use to fill the cooling system. Can't remember what that procedure was now, but I was also told that you don't need the spring in a replacement hose. For what it's worth...Cheers
TommyJ
Old Sep 25, 2008 | 09:03 AM
BarryK's Avatar
BarryK
TommyJ
you DO need the spring in the lower hose. the pressure of the waterpump, especially at higher rpm's, can cause the lower hose to collapse which results in a massive restriction of coolant flow. The result of that is higher operating temps and very possible overheating.
As the hose gets older the rubber breaks down and becomes softer making it more prone to happening.
The internal spring keeps the hose in shape and prevents collapsing
Old Sep 25, 2008 | 11:02 AM
avner's Avatar
avner
I bought the lower hose for my 72 from Paragon and it came with the spring.
for 75 #2233
Avner
Old Sep 25, 2008 | 01:09 PM
dtamustang's Avatar
dtamustang
put the spring in. i spent months and $$$$$$$ chasing an overheat due to no spring.
To Lower radiator hose spring
