Tilt/Tele Rebuild Question
This is the only thing that is holding me up from putting my column back together after completely disassembling it, cleaning/blasting repainting parts etc...
1). You can carefully file the key that is part of the shift tube until it just slips into the shift bowl. You don't want any slop just a sliding fit. I think that the press fit is along the sides of the key.
2). There is a plumbers tool called a Kwiki Plug. It is designed to expand inside a water pipe. I have not seen this tool but my brother-in-law is a master plumber and says that it should work.
The following was eMailed to me a couple years ago. I think that it is describing the Kwiki Plug:
"When I was reassembling mine (shift tube to bowl) I could not find the GM tool to pull the tube so I made one. All you need is one of those expandible plumbers bungs from the hardware store and some threaded rod, nuts, and washers. I just put the rubber between the two washers and inserted the rod into the tube. You can tighten it in place with a long extension from the bottom of the tube. Position the tube in place and position a large socket over the rod so that it contacts the bearing housing. Thus just thread another nut onto the rod and tighten down on the socket drawing the tube up into place. Worked fine for me."
If you are successful I would be most appreciative if you would elaborate on how you did it. I would be happy to include a section in my T&T Disassembly & Repair Paper on the procedure.
Jim Shea
I appreciate your post. I thought about using the plumbers tool but opted not to as I was worried that it might expand the end of the shift tube.
Instead, I inserted a 7/8 half inch drive socket into the tube with an 8 inch carriage bolt that engaged the drive square in the socket. I put a large washer on the other side with a nut and slowly pressed the shift bowl onto the tube. I coated the surfaces with lithium grease to help the process. It worked very well and got the job done with no damage.
I hope this help others!!
Scott
Jim Shea
