gas float
Old Sep 25, 2008 | 01:17 PM
74batmobile's Avatar
74batmobile
Default gas float
so my gas gauge hasnt been workin in months. i figured it was the gauge but the other day when filling up i noticed that my float was suck at the bottom of my tank. I ran some sea foam to make sure it wasnt by sluge or anything and took a hanger i tried to pull it up. and its stuck bad. does anyone know how to remove it? and also is there suppose to be a wire running from the float unit to the gauge? i went under the car and didnt see one.
also if anyone know knows a step by step on how to replace the original gauges to a new autometer gauges that be helpfull
-thanks
Old Sep 25, 2008 | 04:11 PM
dmaaero's Avatar
dmaaero
On my 74 there"s a ground wire that ataches to the guage under the tank.
Old Sep 25, 2008 | 04:13 PM
avner's Avatar
avner
Do you mean to the sending unit in the gas tank?
if you open the spare tire carrier you look up (bottom of the gas tank) near the holding screw of the carrier you should see 2" round 'thing' with 2 wires that go to the sending unit and from this hole you can replace the sending unit, if you don't see that on the bottom of the gas tank you should take out the plastic cover of the spare tire carrier.
Avner
Old Sep 25, 2008 | 05:37 PM
74batmobile
i checked i dont see a black wire anywhere near it.
you think wires makin the float stick at the bottom?
Old Sep 25, 2008 | 07:10 PM
dmaaero's Avatar
dmaaero
no the wires ain"t making the float stick. Do what avner told you, you"ll find the wires an the sending unit.
Old Sep 25, 2008 | 07:51 PM
74batmobile
Avner
you think i need to disconnect the battery before i reattach?
Old Sep 26, 2008 | 05:13 AM
avner's Avatar
avner
When you work with electricity it's better/recommend to disconnect the voltage source.
To gas float
