Ditching front and rear bumper support - any problem?
While rebuilding the car (77) I am planning to leave off most of my front and rear bumper support structure and then attach rigid fiberglass bumpers front and rear and create a seamless appearance.
Do you see any problem with this? Looks reasonable and straight-forward. I also assume I can bond the 74 rear bumper to the 77 body. I know it's somewhat of a mix and match, but I like the clean style of the 74 bumper vs the 77.
Having to build some custom brackets, etc is no problem. Also, I don't know if I'll need the vacuum reservoir at all as I will install an LS3, fixed headlights, hydroboost. Not sure if the huge vacuum tube is needed up front at all anymore
I would be reluctant to remove it, because of the possible damage to other (more vital parts) of the car when even a small collision occurs. If the weight removal is the issue, maybe making a replacement bar out of carbon would help...
Don't remove the whole thing like the picture shows. Notice those pieces bolted on each end of that rear bumper reinforcement? Those were there to add more support for the tail lights. With the fiberglass bumpers they are not needed...I removed mine and have no problems. However, even the fiberglass piece is just a bumper "cover". Don't do something stupid and remove the entire bumper unless you will never drive on the street. You will be risking your life even with a 10mph rear collision.
