help pb,, after headers Installation
Old Sep 25, 2008 | 06:35 PM
c31980's Avatar
c31980
Default help pb,, after headers Installation
I got hooker competition installed with custom made dual exhaust pipe
every thing seems ok ,,but when floor the gas pedal and while shifting
into 2nd gear i feel knocking under my feet , went back to shop who had done the install left the car there for some time to fix it ,, but same thing knocking under my feet during shifting into gear ,, what I think is the pipe he used is not think enough or lack supporting point
Is there any way to hold the pipe firmly away from contacting the body ?? or should i tell him to weld the 2 pipes with one iron piece as
a support to make them more stiffer
idea and feed back ,,are welcome,,,
thanks ,,,regards
Old Sep 25, 2008 | 07:08 PM
tjl82's Avatar
tjl82
does the system look to close, you might want to check your motor mounts if broken the motor will twist up on the drivers side
Old Sep 25, 2008 | 07:34 PM
c31980's Avatar
c31980
good point ,,did not check that tjl82 ,,thanks
To help pb,, after headers Installation
