I am helping a friend over here and need Carburetor info for a 383, SBC motor with an Ebelbrock Performer air gap duel plain square spread boar manifold. Currently have a 600cfm Edelbrock carburetor and it seams to be working good. Will a bigger cfm carburetor work better and still give decent gas mileage?
The heads are 190 CC intake ports, 10 to 1 compresion cam is Duration at 0.006" Lift: Intake: 308° Exhaust: 318°
Duration at 0.050" Lift: Intake: 234° Exhaust: 244°
Lift at Cam: Intake: 0.325" Exhaust: 0.340"
Lift at Valve: Intake: 0.488" Exhaust: 0.510"
Timing at 0.050" lift: Open Close
Intake: 10° BTDC 44° ABDC
Exhaust: 59° BBDC 5° ATDC
Centerlines: Lobe Separation - 112° Intake Centerline - 107°
If by "work better" you mean make more power, I'd say no. That sizing likely keeps you out of the secondaries in cruise and isn't holding the engine back unless you're turning > 6000 RPM. There's always power to be found in a good tune, and there are certainly more tuneable carbs.
I'm running a 388 Stroker with about 400HP and a Holley 650 CFM spreadbore carb. 650 is plenty CFM for a streetable car. If you are looking to take it to the drag races every weekend, then a bigger carb could give more power.
