1980, automatic flywheel, which way to install
Old Sep 28, 2008 | 02:49 PM
chevykid1947's Avatar
chevykid1947
5th Gear
Default 1980, automatic flywheel, which way to install
Installed a 350 engine and automatic transmission with lock up torque converter in a 1980 corvette. The worn starter teeth on the flywheel are towards starter. The torque converter will not go forward enough to touch fly wheel. When installing the bolts you can see it pulling the flywheel. The indention on the flywheel is towards the transmission. Is it backwards? Help.
Old Sep 28, 2008 | 02:59 PM
jerwarn67's Avatar
jerwarn67
8th Gear
the flat side of center hole goes angainst crankshaft.there is a small lip around the center hole that goes toward the transmission,also look at where the lock washers made an impression around the bolt holes if it is a used flywheel.
Old Sep 28, 2008 | 03:39 PM
chevykid1947
5th Gear
Thank you. I installed it the way it came out, by the lock washers and wear of the teeth. Looks like the last installation was wrong. Also looks like I will be pulling the transmission tomorrow. Thank you. LB
To 1980, automatic flywheel, which way to install
