help me pin down axle ratio
Old Sep 28, 2008 | 07:58 PM
baxsom's Avatar
baxsom
Default help me pin down axle ratio
ok so i determined that the axle is not my original one.
the markings on it are 0H008W9E
OH is a marking for later model years.
mine is a 72.
i determined that OH was used in
78 and 79 with a ratio of 3:55
and 80 with a ratio of 3:07
how do i determine now which ratio i actually have.
the only other markings on the axle housing is the stamp GM1.
Old Sep 28, 2008 | 09:24 PM
dmayhew's Avatar
dmayhew
If your speedo and tach are woking correctly then drive the car at 60mph in final drive gear and note the rpm's
my car has P225-70R-15 tires and turnes 2700 rpm's and is a 3:55
David
Old Sep 29, 2008 | 08:03 AM
dmaaero's Avatar
dmaaero
Or you can jack the rear up, mark the rear tire. count how many turns the driveshaft u joint makes for one turn of the tire.
Old Sep 29, 2008 | 08:37 AM
...Roger...'s Avatar
...Roger...
To help me pin down axle ratio
