1975 heater core replacement with a/c
Old Sep 29, 2008 | 03:03 PM
Gardee's Avatar
Gardee
Default 1975 heater core replacement with a/c
Has anyone actually replaced the heater core on a 75 with a/c? I see some posts on here but none are actually for a 75, unless I'm missing something. One of my winter projects is to replace my heater core and all the weatherstipping and seals, etc. Could really use some pics etc. Yes I know what I'm getting into, but it has to be done and also do some work on the a/c vents and ducts.
Old Sep 29, 2008 | 03:16 PM
jnb5101's Avatar
jnb5101
the outer air box must be loosened because the four studs hold the inner and outer boxes together, then remove the right side dash and the inner box. you should be able to leave the control cables in place at the console and disconnect them at the inner box. the center air ducts can also be left in place. pull the right seat out to make this pita job easier. there was an extensive post on this with good pics about a year ago. a straightforward job, just a lot of contourting.
Old Sep 29, 2008 | 03:45 PM
gbvette62's Avatar
gbvette62
Do a search of the forum, there have been many photos and instructions posted in the past. It doesn't make any difference what year you have, the job is the same on ALL 68-82 Corvettes with air. The only variation to the job is that on 68-77's you pull the right side of the dash and on the 78-82's, you pull glove box out of the dash or the whole dash.
Old Sep 29, 2008 | 04:13 PM
76 VETTE's Avatar
76 VETTE
I have done it on my 76.Not too bad of a job. Just take your time and make sure you get all the bolts out of the heater to firewall bolts out to remove it.Have fun!
Old Sep 29, 2008 | 04:53 PM
MrGoFaster's Avatar
MrGoFaster
I pulled all that out not to long ago on my 79 to fiberglass some holes in the box & had to pull the motor before I could actually get it all out to work on it.
Old Sep 29, 2008 | 06:08 PM
gbvette62's Avatar
gbvette62
You don't need to pull the motor to replace the heater core. It comes out from the interior side, the outer box doesn't need to be removed, thankfully!
Old Sep 29, 2008 | 06:12 PM
Solid LT1's Avatar
Solid LT1
This is about THE WORST job to perform on a C3 Vette. Make sure to reconnect oil line to center guage stack when buttoning up the dash (DON'T ASK! why I'm telling you this, it is too painful to tell the story even today over 15 years after the "great oil down".)
Old Sep 29, 2008 | 06:40 PM
Gardee's Avatar
Gardee
Thanks guys, I know I have seen some of the previous posts, just thought that the 75 and 76 were differant because of there being no glove box.
Old Sep 29, 2008 | 09:49 PM
gbvette62's Avatar
gbvette62
Nope, 75 & 76 are the same, the first glove box was 78. The basic job is still the same, the differences in the dash only effect your access to the heater box.
Oh, and the oil line isn't an issue on a 75, they used an electric oil gauge.
Old Sep 30, 2008 | 10:01 AM
Paul L's Avatar
Paul L
Quite correct.
Old Sep 30, 2008 | 12:18 PM
TopGunn's Avatar
TopGunn
I did my 75 w/AC a couple of years ago. I didn't think it was actually too bad, I knew I had to pull the dash and ducting so I prepared myself mentally a little I guess. As stated above, it comes out from the inside and there's some fasteners under the hood to loosen.
I think I have some more detail pics I can post later.
Old Sep 30, 2008 | 12:26 PM
jd1a's Avatar
jd1a
Detailed pics would be nice, I have to do my 75. I'm thinking about extending the tubes down for better access for clamps.
Old Sep 30, 2008 | 02:02 PM
Paul L's Avatar
Paul L
This is the firewall fastener that will give you the heebie-jeebies if you don't know it is there and loosen it off.
Old Sep 30, 2008 | 03:01 PM
Gardee's Avatar
Gardee
Thanks everybody for all the input. For some reason I can't grab anybodys post and quote it, not sure what's going on there. But I will definately check all the past posts and use all the info I got from you guys
Old Sep 30, 2008 | 06:31 PM
TopGunn's Avatar
TopGunn
Here's some photos of the surgery.............Basically what Paul showed you above. There are several vacuum hoses hooked to various places, MAKE SURE YOU LABEL THEM. The red circles were to show someone where the shutoffs were. It looks ugly but it's not that bad a job, just take your time and think about what your doing.
Get these seals for the pipes where they exit under the hood, if you don't the exhaust fumes will get intoi the cabin.
Make sure the seal on this piece if good, it's a source of hot air getting into the duct if it's bad.
Also the seal on the flapper on this piece:
Old Sep 30, 2008 | 06:43 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I wrote this a few years ago. I'm no Jim Shea but I hope it helps...
To 1975 heater core replacement with a/c
