Pulled my hood release handle right off !
Old Sep 29, 2008 | 08:17 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Pulled my hood release handle right off !
Title says it all, I have the hood release handle in my hand. How is it attached ? Is it pressed on or something, I put it back on and now it just pulls right off easy
Old Sep 29, 2008 | 08:38 PM
TimAT's Avatar
TimAT
First time that ever happened!!
No, really, the handle I think is like melted onto the end of the cable. the end of the cable is a bit bigger than the hole in the handle, it's warmed up and stuffed on. Parking brake is the same. Could you maybe tap the hole in the handle and then the end of the cable?? Got to be an easy fix for this one..
Old Sep 29, 2008 | 08:43 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Crapola!! The cable came out of the handle? From what I have read on this it is usually the cable coming out of the attachment point under the hood. I think maybe Tim's idea may be worth a shot. Drill a small hole in the handle and put a small set screw into it to hold the cable into the handle. If this doesn't work, you may have to ride around with the hood unlatched for a while till you can get a new handle.
Old Sep 29, 2008 | 08:46 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
There's good news here...
...You won't have to search for the problem, it's in your hand.
Old Sep 29, 2008 | 08:51 PM
DEMITRISTYLES's Avatar
DEMITRISTYLES
From: You Can't Buy Cool, No Friggin' Way - Mississauga Ontario
That sucks Wayne.
Old Sep 29, 2008 | 08:52 PM
MotorHead's Avatar
MotorHead
I might try and JB weld it on, the setscrew is probably the best route though
Old Sep 29, 2008 | 08:58 PM
76 VETTE's Avatar
76 VETTE
I don't think you can fix it.If you need a replacement ,get a GM one The after market ones don't work well.Don't ask how I know.I have an after market one if interested.
Old Sep 29, 2008 | 09:00 PM
DEMITRISTYLES
So, you're offering him something that you just admitted does not work well...
Old Sep 29, 2008 | 09:12 PM
MotorHead's Avatar
MotorHead
The replacement would be the whole cable then right ?
Old Sep 29, 2008 | 09:25 PM
76 VETTE's Avatar
76 VETTE
Was a joke
Old Sep 29, 2008 | 09:34 PM
76 VETTE's Avatar
76 VETTE
Yes,cable and handel.That after market cable,which is a solid cable, does not return well back to the bracket.GM is more money but works perfect.There are other posts about this .Good luck!
Old Sep 30, 2008 | 12:37 AM
TimAT's Avatar
TimAT
I would too. No sense having junk clutter my garage when I can pass it off on someone else. He never said anyhing about wanting $, just asking if he was interested..
Old Sep 30, 2008 | 01:10 AM
Bowerss2's Avatar
Bowerss2
guess popeye had his spinach
Old Sep 30, 2008 | 10:52 AM
The Money Pit's Avatar
The Money Pit
I did the same thing with mine a couple years ago, and did the el cheapo two part epoxy fix. I let it set up a day or so before I tried to use it, and it's been fine ever since.
God knows I open the hood a bunch.
Old Sep 30, 2008 | 11:25 AM
76 VETTE's Avatar
76 VETTE
Thanx Tim
Old Sep 30, 2008 | 12:23 PM
Crash80's Avatar
Crash80
I went with Gorilla Glue. It has been good since but I know one day it'll do it again. I'll get the Gorilla Glue out again and buy myself a couple more years of hood popping happiness and let the cycle continue.
Old Sep 30, 2008 | 12:27 PM
ksvette74's Avatar
ksvette74
I have broken mine, and I just opened the hood from underneath the car (long skinny arm). Then, I made my own release that I get to from the outside. It folds in under the hood, and you just reach in, grab it, and pull. Made from coathangers (yeah, bubba, I know). Works great, and I am going to take and make a better looking version here soon that does not look so bubba-ish.
Old Sep 30, 2008 | 02:25 PM
MotorHead's Avatar
MotorHead
I've got some of that stuff, maybe I will try that
Old Sep 30, 2008 | 10:39 PM
nutseynut7's Avatar
nutseynut7
Had it happento me. I used that atomic glue that u see at car shows the stuff u keep in the fridge. Filled handle let set one day still good after one year ,I open the hood many times a week
To Pulled my hood release handle right off !
