383 rod question
Old Sep 29, 2008 | 08:20 PM
76projectstingray's Avatar
76projectstingray
Default 383 rod question
when building a 383 , when would you use 5.7 rods or 6" rods. what would make that change? the type of piston ??
Old Sep 29, 2008 | 08:26 PM
Gordonm's Avatar
Gordonm
I answered it a little in your other post but I am running a 5.7 rod. The guy who machined mine runs the exact rod in a 8600 rpm drag motor and has for 3 seasons without any failure. He did not like having the wrist pin into the oil ring. He said the minor gain in going to a 6 inch rod is far outweighed but having a stable oil ring. He is the expert and I have had no issues running a 5.7 rod. I understand the 6 inch rod has a little beter ratio but for a street motor I doubt you would see or feel any difference. My motor will never see 100,000+ miles either.
Old Sep 29, 2008 | 09:00 PM
BLOCKMAN's Avatar
BLOCKMAN
We have had zero problems with 383's and rings spacers in the past.
Mahle 6 inck rod pistons don't use ring spacers with their ring package.
and these have worked fine as well
To 383 rod question
