help me mod. a '77
Old Sep 30, 2008 | 06:57 AM
RRROBB's Avatar
RRROBB
Default help me mod. a '77
I am in the process of updateing a '77. I will be installing a 5 speed trans. (change over from auto.) Steeroids and side pipes.
apparently the sidepipes get in the way of the rack & pinion and the
z bar for the clutch gets in the way of the side pipes.
is there any particular order that would make things easier to install
Old Sep 30, 2008 | 08:10 AM
Durango_Boy's Avatar
Durango_Boy
Maybe consider swapping to a hydraulic clutch. I have a bit of info on what it takes to do the swap easy and cheap using some salvage yard parts including an older truck bell housing, a Honda Civic master, truck slave and fork...and it should all clear just fine.
Old Sep 30, 2008 | 11:41 AM
SteveG75's Avatar
SteveG75
Z-bar fits fine with Hooker sidepipes. Been running mine that way for 4 years now.
To help me mod. a '77
