1980 hood fit
Old Oct 2, 2008 | 08:48 PM
crossram's Avatar
crossram
Default 1980 hood fit
I bought a one owner 1980 vette and the hood is slightly low and the front. 3/16. Do these hood warp over the years? Can it be warped back?
If I adjust it up in the front with shims it will be slightly high on the sides.
Old Oct 2, 2008 | 09:42 PM
wnmech's Avatar
wnmech
Use a hood alignment bumper and move it either way until your hood aligns then glue it down. Here is a link to what they look at from Ecklers.
http://www.ecklers.com/product.asp?p...9&dept_id=1459
Old Oct 2, 2008 | 10:49 PM
crossram's Avatar
crossram
Im not sure how that would lift the front or nose of the hood the 3/16 when shut. I would like to think I am fairly savvy but not sure how the bumper works in my situation. Can you explain?
Are you talking about the bumpers above the radiator support? I removed them first and no change. It looks like it would make it worse to have higher ones but I may be wrong.
Old Oct 2, 2008 | 11:31 PM
thegazman's Avatar
thegazman
Default thegazman
I had the same problem on my 79. I corrected it with new hinges. You can then adjust the hood fit with shims under the hinges.
Old Oct 3, 2008 | 07:56 AM
crazywelder's Avatar
crazywelder
The hood surround panel may have lost it's bond to the headlight reinforcement. When the bond breaks at the rear edge of the reinforcement, the hood surround pops up and there will be a gap between the headlight reinforcement and the surround. Check the surround panel directly in front of the hood to see if you can push it down against the reinforcement and regain hood to surround alignment.
Old Oct 3, 2008 | 08:27 AM
...Roger...'s Avatar
...Roger...
Old Oct 3, 2008 | 08:34 AM
...Roger...
Are there any of the little blocks of rubber along the side? If you remove them the hood will drop in the center and the nose will come up...in time.If some one has tried to contour the hood to the fender line by using the rubber blocks they could have arched the hood too much.
Old Oct 3, 2008 | 08:39 AM
...Roger...
The hinge pivot must be tight to be able to contour the hood using the rubber blocks and shims.If the pivot is loose and you use a block the hood just goes up rather than bending the hood using the pivot as an anchor point.
Old Oct 3, 2008 | 12:22 PM
sam79's Avatar
sam79
Hey Crossram, I have the same issue on a 79 vette. Can you provide a picture of the hood shut. I will post a picture when I get home tonight. Maybe you and I can resolve this issue.
Old Oct 3, 2008 | 01:25 PM
wnmech's Avatar
wnmech
I apoligize I misread your post and thought you were low on the sides. My Boo Boo
Old Oct 3, 2008 | 02:14 PM
a1sensei's Avatar
a1sensei
This is what you need. Put them in the channel of the fender under the hood (or be cheap and use heater hose).
http://www.zip-products.com/Zip/prod...31679760686797
God bless, Sensei
Old Oct 3, 2008 | 02:55 PM
kevinator80's Avatar
kevinator80
Not arguing here, just saying.
I don't think the fiberglass across the front pops up, rather the metal piece that is bonded falls down giving the impression the glass has poped up. I may be wrong or we both may be right.
Regardless, I don't think everyone here is reading his post correctly. The way I understand it is his hood lines up every where else except right in the center and it suddenly takes a dive as if the center (six inches to either side of center) is warped. My 81 has a similar problem and I have often thought that perhaps the hood had warped at some point. My fix was to customize my hood starting at the dip and take it all the way to the cowl. I guess I didn't fix it as much as I covered it up some.
Old Oct 4, 2008 | 07:52 PM
wesleyshawn's Avatar
wesleyshawn
I have a similar problem on my '79, the hood lines up at all 4 corners and on the driver's side, but on the passenger side mid way between front and rear it is quite low compared to the fender. I used a contour gauge to compare the fenders and both are shaped the same, it just seems the hood does not have enough arch on the passenger side.
Old Oct 4, 2008 | 09:55 PM
...Roger...
The factory used these pieces of rubber under the edges of the hood to force the hood to match the fender.
To 1980 hood fit
