My 82 is throwing codes
Old Oct 3, 2008 | 05:24 PM
PhyscoVette's Avatar
PhyscoVette
Default My 82 is throwing codes
On the way into work this mornig she started running like crap and trowing the check engine light on.
So I get to work and pull put the ol paper clip and I am throwing a code
15 Coolant Temp sensorvoltage high
33 Mao Sensor signal voltage wa too high (low vacuum) for 5 sec when throttle was under 2%
I am confused to why she is doing this the only thing I can think of is I havent put a thermostat back in since the old one was stuck open so mabye it is running to cold?
Pleae help i really dont want to have her towed home.
Old Oct 3, 2008 | 07:37 PM
terry82's Avatar
terry82
sounds like a coolant temp sensor went bad .change the sensor in the front of the intake manifold above the waterpump.i also would put in a new thermostat
Old Oct 5, 2008 | 02:56 AM
worms713's Avatar
worms713
Also check the wiring/plug to the sensor - my 82 did the same thing and I barely made it home. My problem was the coolant sensor plug and the wiring to the plug - it threw the same codes.
Old Oct 5, 2008 | 12:32 PM
tracdogg2's Avatar
tracdogg2
First put a thermostat in it. The coolant temp much reach 155 to go into closed loop.
Ignore the code 33 for now. Possible false code.
Check the coolant temp sensor plug. If it's round, replace it and the sensor.
Mike
Old Oct 5, 2008 | 06:24 PM
jdp6000's Avatar
jdp6000
Mike
82 won't run without a stat.Keep in mind coolant temp sensor takes a reading from directly below the thermostat. It send the results to the ecm which determines if the engine is hot or cold.
As for the MAP. Because of the rough idle it probably sensed well under 20 psi and gave you a code. Probably related to the cooling problem. As indicared above ignore it for now.
Jim
Old Oct 10, 2008 | 01:15 PM
PhyscoVette
Default Update
Well she is back on the road
So do es anyone knoe how hard it is to find the updated temp sender for these cars? I finally found one at schucks and then after searching thru a few catalogs we found the pigtail. You would think that the replacement sender would come with the updated pigtail Uh NO!
So anyways I went home last night after finding the sender and come to find that the cause for the problems was the map sensor comming apart. Not that the temp sender didn't need replacing since it was the original and was pretty well worn out.
Thanks god I happend to have a new map sensor on the shelf since I didnt discover it was bad untill ten pm and I really wanted to drive her today since it may be the last nice day we get.
Thanks for everyone who thru in there ideas it gave me a great place to start.
Later
Physcovette
Old Oct 10, 2008 | 06:09 PM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
I got my coolant sensor from NAPA. I still have the box if you need the model #. It came with the new pig tail.
Dav
To My 82 is throwing codes
