7mpg gas drinking beast!
The other thing i'd look at is the catalytic converter..... if you still have one. It could be almost plugged.
Are you saying that when you set the timing to a reasonable 10°-12° with the vacuum advance disconnected and then when you hook up the vacuum advance, you cannot get the idle speed down to 700-800 rpm with the idle adjust screw on the driver side of the carb?
If I understand you correctly, something is not right. Have you checked your throttle cable to see if it is keeping the throttle slightly open? If it's not the linkage, then start looking for a vacuum leak as others have suggested.
The symptom is: If I set the idle speed to minimum the car don't shut down! And that might be ok right? Instead idle bottoms on what sounds like 500rpm on ported vacuum, on full mainfold vacuum it sounds like 750.
The cable is ok, I had to fabricate the linkage and build a way to adujst the cable slack as you can see on the pics.
My tach is not accurate so I don't have a precise reading of the idle...
The vacuum leak is not ruled out,I still have to investigate it further.
So the harder the better(as long as it don't cost me more
And yes this plug specs are colder that all the others, it's even hard to find them as in 76 they went back to the projected tip ones. This car already has a higher comp ratio an I saw improvement from increasing the timming, the spark plug gap, now the spark plug itself, the car is definetelly running better and sounding differently now, lets see how it reflects on mileage.
it has 2" duals all the way to the back, the last section and mufflers look beaten up, I'm considering a upgrade to 2.25" or 2.5", not sure about H link, cheap summit headers? Suggestions???
Zwede, I have some pics for you, I'll post back once they are online.
Thanks guys!
Fábio.
Let me know what you think...
You'll have to tune the holley to get max economy. If tuned right it will not loose any response or power, just improve economy. But it can get tricky to do them right and I highly recommend a wideband O2 meter.
I'm excited about playing with a new tool but is it really necessary? Any other guys with Holley StreetAvenger on vettes around??
Thanks,
Fábio.
As I recall Lars has found these carbs to be jetted very lean. Here is one of his threads.
http://forums.corvetteforum.com/show...street+avenger
My SA dont seem to be suffering from these problems but I'm just a rookie on this you know... I'll investigate further...
Fábio.
