Old Oct 6, 2008 | 06:46 AM
Jonathan502's Avatar
Jonathan502
Default 275/45-18
Hey!
I am going to buy american racing tt2 rims 17*8 with 225/55-17 up front and 275/45-18 rear.
Does 275 and 10" wide rim fit on a corvette with vbp 420 monoleaf in the back? stock trailig arms.
I am greatful for any help..
Old Oct 6, 2008 | 07:14 AM
Gordonm's Avatar
Gordonm
Why are you running such a narrow tire up front? I run a 255 45 17 up front with a 275 40 18 rear. I do run a 10 inch rim out back on stock trailing arms with e brake cable rerouted. My spring is 1/2 shorter on both sides and the rear sway bar will not fit.
Old Oct 6, 2008 | 07:24 AM
Jonathan502
The reason is I want the same profile front and rear. But I know the rear tire i a little larger in diameter. And I need the ground clearance 225/55-17 gives me. I have 3.5" collector on my Hooker headers.
So I cant fit an 10" wide rim rear without shortening my spring and remove my sway bar?
If i choose 8" wide rim rear what backspacing should I choose? and is 255 a good choise för 8"?
Old Oct 6, 2008 | 08:47 AM
Gordonm's Avatar
Gordonm
You can fit a 10 inch rim. It is tight but does fit. Mine have a 5.5 backspace. Not sure on the spring. It would be very close to having the spring contact the rim. The sway bar, no way will the stock style sway bar fit. If yo urun a 8 inch rim which is stock size a 4 inch backspace is needed. The 255 tire will work very good. I just wanted as much rubber as I could fit.
Old Oct 6, 2008 | 08:54 AM
Jonathan502
Okey!
thanks for the info
I am considering 245/50-17 front and 255/50-18 rear. rear wheel bigger but i kinda like it that way.
so 4" backspace both front and rear, do you think that will look funny?
Old Oct 6, 2008 | 09:12 AM
Gordonm's Avatar
Gordonm
Should not be to bad. The fronts are a 4.8 inch sidewall and a 26.6 diameter. rear will be a 5 inch side wall and a 28 inch diameter. Yes a 4 inch backspace front and rear if you are going to a 8 inch wide rim.
Old Oct 6, 2008 | 09:38 AM
Jonathan502
I might try that, if I dont choose Coys rims, they have 18*9.5" Will they fit my corvette with 5.5" backspace?
Old Oct 6, 2008 | 10:35 AM
Gordonm's Avatar
Gordonm
Yes they will. I was going to go that size but the TTIIs did not come in a 9.5 size.
Old Oct 6, 2008 | 11:51 AM
Young69Owner's Avatar
Young69Owner
I have Hooker Headers and 4" pipes and 255 should fit fine up front. Experts?
Old Oct 6, 2008 | 12:48 PM
Jonathan502
Are you completely sure?
So I dont have to modify leaf spring or remove sway bar?
Old Oct 6, 2008 | 05:12 PM
70 LS1's Avatar
70 LS1
Can't say about your poly spring, but I have 275/40/18 on a 9.5" rim with 4 7/8" backspacing with well over 1/2" clerance to anything. I would to 5 1/4" backspacing next time. Stock trailing arms, no ebrake cable.
Old Oct 6, 2008 | 06:36 PM
Gordonm's Avatar
Gordonm
Yes I am. I talked to them a few times. The 18X10 is a custom order rim. They make them in batches of 20 or 30 at a time. The first two I waited for 6 weeks. 1 of them was bent. The next one took 1 week, it was bent. I had another in 3 days it was fine. They had a few of them is stock due to they make a few more than ordered.
Old Oct 6, 2008 | 07:35 PM
Bee Jay's Avatar
Bee Jay
I run 275-40/18 tires on 18x9.5" rims, stock trailing arms, modified sway bar. But stay tuned. I just removed my stock trailing arms and am having offset trailing arms built up. I hope to run 18x10.5 rims with 295-35/18s with the offset TAs and modified sway bar. Stay tuned.
Bee Jay
Old Oct 7, 2008 | 05:47 AM
Jonathan502
Will 255/45-18 up front rub? on a 8" wide rim with 4" bs? Might go with 255/50/18 rear..
Old Oct 7, 2008 | 06:54 AM
Vesa's Avatar
Vesa
I have 255/50/17 all corners and front I had to file a bit inside the fender but now fits fine...
Old Oct 7, 2008 | 07:31 AM
Jonathan502
Ok. maybe I will choose 245/45-18 front and 255/45-18 rear..
To 275/45-18
