WANTED- info on TPI conversion
S L O W compared to the '84 or of course the '07.
So, has anyone done the conversion? I have found a tpi unit with module from a donor here for 500, but think its going to be 2g before it is done, is it worth it or better off to dump 2g into another engine?
I know I need 55 psi fuel pump, wiring harness, MAP, MAF sensors, etc etc etc, and then there is no guarantee it is going to work, could be a waste of money.
Insight?
the car WAS a muncie 336 geared car got 12-14 mpg at best, with the stock Qjet on it...L48 engine rebuilt by P/owner with a mild cam stock exhausts....
I stuck a TPI on there for 750 bux or so, and it jumped to a highway cruise at 70 doing some 4000 rpm getting 24 mpg....
good for maybe 275 hp or so....
since then with a move south, more freeway useage, and higher speeds, 4000 cruise was not dooable for any time....
in went a roller engine 11+ years ago....a cammed up ZZ4 engine with large runnered TPI and getting 22.2222 mpg at 90 mph cruise....and I was being pushed....some gas crisis....4+ bux/gallon and traffic FLYING, go figger....
I now have a 200 4r automatic in there for some 3 years now...
for the overdrive...
i'ts a speed density system, using the stock junkyard computer and wiring harness ends, being an ole ET I can solder a wire with my fingertip......
I highly recommend the swap as it's a direct bolt on and it's even cheeper today to do it than 15 years ago....
last winter, I modded up a LT1 intake manifold and put it on there in place of the TPI, but kept everything else the same....
runs like a bat outta hell....
wire it like a '91 F body V8.....follow the diagram religiously....
chips/cal pack is about 150 bux these days....
so total cost about 500+ bux.....roughly....
BUT you have to do your own install....and learn something....
Edelbrock Performer heads $1150 a pair
Comp roller cam $300
Edelbrock Performer intake $130
Intake with carb, cam and lifters(edelbrock package deal) $640
Misc. odds and ends $500 maybe
so for a little over $2k you can add a 4th leg.............
First you have to determine whether you want mass air flow or speed density. The C3 is more conducive to speed-density due to space issues. Mass-air flow is easier to make engine changes without PROM changes. If you are technically proficient enough to make a Camaro harness work they can be bought for $100 or less. I have been told that you can also use a 3.1 Corsica or Cavailier harness with a little work, it uses the same 7730 Speed-Density ECM. Aftermarket harnesses range from about $300 for Painless to $500 for Howell to $700 for Street and Performance. Howell makes a great harness, but for a Tuned Port they do not make one that will control the converter lockup on a 200R4/700R4/4L60 transmission. If you are running a manual or non-overdrive-automatic transmission I highly recommend them. I have heard great things about Street and Performance harness, but do not have first hand experience with them. I also have a Fuel Injection Specialties (FIS) harness and it is OK. The ECM can be had used for $10-50. A good external fuel pump will cost at least $100. I use an 88 Ford Truck external pump, $114 from CarQuest, made in Texas by Airtech. If you have a 78-82 you can use your fuel tank with an 82 sending unit and a TPI pump. An aftermarket PROM with VATS and Emissions codes removed will be $100-200 depending on source and complexity. You will have to add an oxygen sensor to your exhaust, $20 for the sensor, $5 for the weld-in bung, and say $25 for an exhaust shop to weld it in if you can’t. Some harnesses use VSS and some do not. An auxiliary VSS sensor is around $75. To install a TPI I say figure at least $800 plus the TPI unit and whatever repairs are necessary to bring it up to useable status. I have TPI/700R4 in my 69 Corvette (Howell harness) and an 83 Pickup (FIS harness) and I love it. Starts good, great torque, good fuel mileage, easy to swap onto stock engines (although both of mine are complete engines out of 90/91 ‘Vettes).
Differences in years
All Corvette TPI intake manifolds work with the older (through 86) iron heads and the factory aluminum heads through 91. F-body TPI intakes use the upright center bolts on 87-92 and thus fit all 87-95 iron heads (non LT1). Either can be swapped to fit the other with some drilling. F-body has the fuel lines come out on the drivers side and has a central port for EGR. Corvette has fuel lines that come out on the passenger side and has an external port for EGR. Corvette fuel rails fit F-body intakes and vise-versa. The runners are all the same through the years, but the LH runner has a hole for a 9th injector in the 85-88 runners. This can be plugged off if you get a nice LH runner and don’t want the 9th injector or decide to run speed-density. The plenums all physically interchange, but 90-92 have an extra vacuum port for the MAP sensor used with the speed-density computers and wiring. 89 is an odd year, it is mass-air flow but without the 9th injector. 89 up throttle bodies can be used on all years, but a 85-88 throttle body requires a ½” hole be drilled in the front of a 89-92 Plenum for idle air. 89-92 Throttle bodies have a bit more desirable cable attachment. The cable attaches around a circular linkage which has a smoother actuation than the straight linkage on the 85-88. The Corvettes have an aluminum plenum extension over the distributor, the F-body extensions are plastic. The Corvettes use an HEI coil-in-cap distributor for 85-91 (Delco 1103680). 85-86 F-body also used a big-cap distributor. 87-92 F-Body used a small cap distributor with an external coil (Delco 1103479). This same distributor is used in the 87-95 5.0/5.7/7.4 TBI injected trucks. The F-body intake gets it's exhaust for EGR from the center passages in the heads like most SB Chevys. A Corvette intake gets it's EGR exhaust from the RH exhaust manifold/header through a flex-tube to an opening near the distributor-no center passages in the intake. If you are required to keep EGR and you have a Corvette intake, I recommend getting the C4 exhaust manifolds. They are like mini-headers, and have a 2 1/2" outlet. I have them on my 69 and like them.
As far as a throttle cable to use, on my Vette, I used a TPI Corvette cable, 1990 I think (about $20 new GM) but you have to cut the end off inside the car and use a hood-release-cable end (Corvette Central 342138 "cable stop") to get it the correct cable length (the housing is OK). You must use a cable from the type car your throttle body came from if you want to have a chance of not cutting it. Again, 85-88 use a straight pull, while 89-92 have a circular attachment for more smooth actuation and so the inner cable is longer. On my 83 truck I used a TPI F-Body cable and it was OK, but I had to coil it up into a loop in the engine compartment because the housing was so long. I also TPI'd a 72 Chevy truck and used a 90 350 TBI truck cable for it. It was 1/2" short outside if anything, but I was pretty pleased with it all told-I didn't have to shorten it. In a Vette it might be about right. In all vehicles I've done you need a die grinder to square the firewall hole off a bit. All vehicles I've done used the late throttle-body.
Why to get it
I would look into a TPI. They start immediately in winter, have great vacuum, and will get great mileage. I can open the headlights and the wiper door at the same time with no hesitation at all-solid wooomp. With 3.70 gears (and a 700R4 overdrive) I get 18mpg city and 22+ highway. With 3.55 or 3.36 it would be even better. You can probably find a used Corvette TPI engine for $1000 and with an $800 harness/computer/fuel pump you would be set. On a 78-82 you can use the stock fuel tank with an 82 sending unit and TPI pump and be in better shape than 68-77 with an external pump. With the Vette TPI you would have aluminum heads that would remove weight. Even with an F-body iron-head TPI 350 it will be less weight than a stock intake. It will bolt up to everything in your car, use stock accessories, use your transmission, and the visual appeal is awesome. Don't be afraid of fuel injection, it really works.
As far as websites see:
www.corvettefaq.com for conversions or more TPI info at www.fuelinjection.com
Here's a link:
http://www.affordable-fuel-injection...Fuel+Injection
This should give you an idea as to maximum cost. Let us know what you end up doing.
DC
That is awesome information, thank you so much guys!
I found a great deal on one, looks like I found another winter project.
If I could sell my rashed 2008 hayabusa I might buy a complete engine- anyone want a Busa with factory warranty? LOL
I used Street and Performance wiring harness with tags on each plug (so easy a cave man can do it) and step by step instructions.
But I used all new parts (harness, Throttle body, distributor, ecm, custom chip, ect). The only thing used was the intake.
If I did it all over again I would have just bought a complete LT1 engine and harness out of a donor car and went that route.
But as far as parts, go to www.tpiparts.net that's where I got 99% of the parts to do the swap. And don't forget these books as well.
http://cgi.ebay.com/ebaymotors/Chevy...mZ360095335568
http://cgi.ebay.com/ebaymotors/Jagua...mZ220291886856
