Rear differential cooler
Old Oct 8, 2008 | 02:36 PM
V-Twin's Avatar
V-Twin
What shop? I thought you worked for the government? Did you open up a race car shop?
Old Oct 8, 2008 | 03:09 PM
...Roger...'s Avatar
...Roger...
Speaking of HD caps. Has anyone seen any strength testing between the straps and the HD caps? I've replaced a bunch of HD caps being run on the street with mild motors because they stretch out leaving the u-joint loose.I've never seen this with the lighter duty caps even with some cars running big blocks and large tires.
Old Oct 8, 2008 | 04:38 PM
68/70Vette's Avatar
68/70Vette
The differential gets hot because of the HP loss. An acquaintance of mine has spent really big bucks on his C4 and one thing he recommends is having the differential REM treated. Don't know what the acronym stands for, but the idea is that the ring and pinion are given a quick dip in a corrosive bath and then the ring and pinion are placed in a vibrating tub of small abrasive ceramic particles. This process is repeated two or three times and the net result is that the ring and pinion are left with a mirror like surface finish. The story is that friction between the ring and pinion is greatly reduced, heating is reduced, and you don't need a diff cooler. He's had the gears in his transmission similarly treated. The abrasive treatment doesn't go deep enough to disturb any surface heat treatment. The REM process produces a noticeable horsepower increase at the rear wheels according to their brochure. I'll try to get back with the name of the vendor.
