'69 L46 Gear ratio
Old Oct 7, 2008 | 04:53 PM
split71's Avatar
split71
Default '69 L46 Gear ratio
What would is the standard gear ratio w/ 4sp for a 350hp car? Would the M20 be the standard 4 speed with the M21 being optional?
TIA,
Mike
Old Oct 7, 2008 | 07:06 PM
LT-1 kid's Avatar
LT-1 kid
i had a 70 350-350 and the standard gear for a m20 is a 3:36 and m21 would be a 3:70. m20 would be standad, 350 hp only avalable with manual trans only.greg
Old Oct 7, 2008 | 07:09 PM
wfo76's Avatar
wfo76
I believe the 69 order form just said something like "L46, requires either M20 or M21 4-spd" so you had to pick one.
M20.....3.36 std, 3.55 opt
M21.....3.70 std, 4.11 opt
For 70-up after the 3-speed was dropped, the M20 became standard but it wasn't in 68 and 69.
Old Oct 8, 2008 | 07:50 AM
split71's Avatar
split71
Thanks for the replys, I guess I have to figure out which tranny the car has. This is a car I'm going to look at on Saturday, 2 owner Riverside gold/black interior coupe in what looks like nice driver condition.
Mike
Old Oct 8, 2008 | 08:30 AM
wfo76's Avatar
wfo76
If you can see the tranny stamp on the passengers side, starts with a P and ends with either A (M20) or B (M21),
early 69's won't have the A or B.
Also rear end codes stamped under the differential,
M20
AK - 3.36 open (std)
AM - 3.36 posi (opt)
AN - 3.55 posi (opt)
M21
AS - 3.70 open (std)
AO - 3.70 posi (opt)
AP - 4.11 posi (opt)
Old Oct 8, 2008 | 08:39 AM
GTR1999's Avatar
GTR1999
Almost 40 years later, there could be anything in there. Many diffs were swapped or blown up over the years. Look at the housing date code and see where the RPM is @ 60 mph.
Old Oct 8, 2008 | 09:35 AM
split71's Avatar
split71
wfo, great info! While I agree anything can happen in 40 years this car looks unmolested...I guess I'll find out when I look at it.
Old Oct 8, 2008 | 10:49 PM
PRNDL's Avatar
PRNDL
you can easily tell if the trans is M-20 or M-21 by driving it. Drive along slowly in 4th gear and shift down to 3rd while keeping the speed constant. Note rpm in 4th and rpm in 3rd and you will know if it is wide ratio trans or close ratio trans.
To '69 L46 Gear ratio
