Removing struts / shock mounts
Old Oct 8, 2008 | 10:53 AM
radiojoe's Avatar
radiojoe
Default Removing struts / shock mounts
I've read a lot of posts on here about how difficult it is to remove the shock mounts when you want to replace the struts. I soaked mine in solvent for 3 days, then hammered the crap out of them with a 4 pound sledge hammer, and did manage to move them this way, but it was still difficult. Then, I went and got a 2 jaw gear puller (performance tool part number W87122) and was able to use that. I got the shock mounts out in about 2 minutes. I should have done this a week ago.
Just a heads up for anyone doing this job- skip all the other advice and just get that gear puller.
Old Nov 2, 2011 | 10:52 PM
Mark Hawkins's Avatar
Mark Hawkins
Hey Radiojoe, where'd you find that gear puller?
thanks,
Old Nov 3, 2011 | 09:00 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I have always used an air hammer and it works well,maybe you should post a pic of the puller.
Old Nov 3, 2011 | 12:48 PM
Rally68's Avatar
Rally68
Please post a pic of the puller setup. I'm wondering if the puller would've worked without the hammer first...? I have tried this BTW--it didn't work for me
Old Nov 3, 2011 | 01:11 PM
RescueDad's Avatar
RescueDad
Air hammer is the way we did it too. No problems.
Old Nov 3, 2011 | 03:06 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
When I used the air hammer I keep the nut install it backwards and hammer till it's loose, the nut prevents the mount from flaring so it will still come out. I have pics if you want.
Old Nov 3, 2011 | 04:30 PM
Rally68's Avatar
Rally68
I'd like to see a picture please.
To Removing struts / shock mounts
