ring gear spacers
Old Oct 9, 2008 | 11:12 AM
curtis75's Avatar
curtis75
Default ring gear spacers
I need to buy a spacer to run a set of 4.10s in my 3 series carrier. I see that Tom's sells them but I cant find a price for them. who else sells them and how much are they?
Old Oct 9, 2008 | 11:26 AM
avner's Avatar
avner
Ask forum member GTR1999 he is the dif' specialist here.
Avner
Old Oct 9, 2008 | 12:32 PM
GTR1999's Avatar
GTR1999
Hi Avner
I would not use a RG spacer, they have loosened up in the past and then you blow up the diff. You're better off buying a gear set made for a 3 series case. I just built a nice HD 411 diff for my sons 75. Runs smooth and quiet, no spacer.
Old Oct 9, 2008 | 01:28 PM
curtis75's Avatar
curtis75
ya if I was buying a new set of gears that would defenatly be the way I would go but I found a deal on a used set from a local guy.
Old Oct 9, 2008 | 04:56 PM
Belgian1979vette's Avatar
Belgian1979vette
Originally Posted by GTR1999
Hi Avner
How is the performance after that change ?
Old Oct 9, 2008 | 05:17 PM
GTR1999's Avatar
GTR1999
It ran great until he blew up the tranny!!!!
Old Oct 9, 2008 | 05:18 PM
GTR1999's Avatar
GTR1999
Good luck, I stay away from used cams and gears. Be sure to use 271 loctite on all the bolts.
Old Oct 9, 2008 | 05:29 PM
Amelio's Avatar
Amelio
what about using the thicker ring gear like U.S gear sells any experience with those?
Old Oct 9, 2008 | 05:35 PM
GTR1999's Avatar
GTR1999
That's what I use Toms(US Gear)
Old Oct 9, 2008 | 06:17 PM
Gordonm's Avatar
Gordonm
Talking from experience NEVER use a spacer. I blew my 4.11 rear with a spacer at the drags. Long expensive flat bed ride home. Use the thick ring gear. I now run a 3.70 gear
Old Oct 9, 2008 | 08:52 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I agree 100% that a ring gear made thicker is the best way. Years ago the only way was spacers or a new posi.
I can tell you that usually it was the bolts that came loose on the spacer deals. If you managed to keep the bolts tight...they held fairly well. I ran one in a Camaro for many many years running high 10's on motor and 9's on the juice. Sometimes with an automatic and sometimes with a stick.
You're already using used gears and that will be a challenge enough to keep quiet. If you're not going crazy with HP and slicks and stuff....you might get by with a spacer. Just spend the time to make sure there is no runout and as mentioned make sure bolts are correct and use Loctite.
JIM
Old Oct 9, 2008 | 09:27 PM
curtis75's Avatar
curtis75
The car isn't crazy but mildly healthy. its a 383 pushing about 400 hp with a T56 6-speed. It will run at the track a few times but not on a regular basis and probably never with slicks. I realize that the thicker gear is a better way to go but its hard to pass up a set of gears for $50. I no a few people running spacers with no complaints so I'm not really worried about it. No one has answered the question yet, how much is a spacer?
Old Oct 9, 2008 | 09:33 PM
chris75stingray's Avatar
chris75stingray
http://www.jawsgear.com/Parts_And_Ac...g_Gear_Spacer/
heres one for 35 . i don't know if it fits a corvette diff though
Old Oct 10, 2008 | 08:47 AM
redvetracr's Avatar
redvetracr
I have a used one you can have for $25+ postage...send a PM if interested.
redvetracr
Old Oct 10, 2008 | 12:35 PM
stinger12's Avatar
stinger12
How do you know that you will be able to set up the gear pattern correctly with a cheap set of used gears?
Old Oct 10, 2008 | 04:44 PM
curtis75's Avatar
curtis75
I know a few guys that have run used gears so long as you take the time to shim them properly they should work fine.
To ring gear spacers
