Automatic Transmission Jerk
Old Oct 10, 2008 | 01:24 AM
jaycall88's Avatar
jaycall88
Default Automatic Transmission Jerk
So lately when Im driving her when i shift from any gear (Automatic transmission) there is a big jerk.
For Example:
From Neutral i shift to Reverse the car would jerk then run smoothly. This also occurs when shifting into Drive.
has anyone had experience with this type of problem ?
Old Oct 10, 2008 | 02:00 AM
Peterbuilt's Avatar
Peterbuilt
Default Might be an easy fix.
Is the idle to high?
Check the differential bushing.
How are the U joints? PG.
Old Oct 10, 2008 | 10:45 AM
Fubba's Avatar
Fubba
For Example:
As said above, idle could be too high. This is also a sign of the torque converter going out.
To Automatic Transmission Jerk
