horn contact
Old Oct 12, 2008 | 06:19 PM
jnb5101's Avatar
jnb5101
Default horn contact
on a 72, is there a difference between the standard and the T&T columns? the contact that came with my T&T column is doa, and i found another contact in my junk box(don't know it's origin) and they look identical.
thanks, jeff
Old Oct 12, 2008 | 09:20 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The difference is the leg length. If it is exactly like the other one you will be fine as long as the other one was correct. The leg off the bottom has to make contact with the lower spring loaded contact when screwed down.
Willcox
