Engine Priming
Old Oct 12, 2008 | 11:07 PM
DJordan442's Avatar
DJordan442
Default Engine Priming
I have read quite a few threads on this and know that everyone says to use a high speed drill with the appropriate tool or bottom of an old distributor. I do not have a high speed drill and am wondering if an air ratchet is an acceptable replacement. Anyone ever use this method? thanks
Old Oct 12, 2008 | 11:27 PM
TimAT's Avatar
TimAT
You don't really need a "high speed" drill. what you DO need is one that's tough enough to run the oil pump. I use a 1/2 air drill, but I've got lots of air. (and before someone jumps on that-- mostly it IS hot air).
If you use an electric drill and don't have a 1/2" use an old drill- it'll smoke it. Your ar ratchet might work, but it won't spin fast enough to get much pressure.
Old Oct 13, 2008 | 01:00 AM
BigBlockTank's Avatar
BigBlockTank
I used a cordless drill set on torque setting, not higher speed setting. Don't forget to put an oil filter on before doing this, don't ask how I know this.....................but I do know this for a fact.
Old Oct 13, 2008 | 02:12 AM
Rockn-Roll's Avatar
Rockn-Roll
air gun should work fine...it's the torque that you need.
Old Oct 13, 2008 | 10:53 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Yep. by Air Gun I assume he meant Impact Wrench. That's the tool with the amount of torque & speed necessary.
Old Oct 13, 2008 | 12:39 PM
billla's Avatar
billla
St. Jude Donor '14
Whew - I would not use an impact wrench for this IMHO. A standard electric drill is fine - just recognize that you're taking some life out of it You're just looking to prime to get oil showing at the rockers - that's all you need.
Old Oct 13, 2008 | 01:01 PM
Durango_Boy's Avatar
Durango_Boy
Another tip, have someone hold the drill and priming tool while you rotate the engine slowly with a strap wrench or something similar. I usually prime until oil comes out, and I rotate a few times past that.
Old Oct 19, 2008 | 12:57 PM
DJordan442's Avatar
DJordan442
Thanks for all the great advive. I will be ordering the priming tool today and get it primed next weekend
Old Oct 19, 2008 | 09:40 PM
tnovot's Avatar
tnovot
Many auto parts stores like Auto Zone will loan the tool free. You pay a deposit and get it returned when you return the tool. They loan others besides the oil priming tool also.
Terry
Old Oct 20, 2008 | 09:43 AM
75 Red Vert's Avatar
75 Red Vert
Make sure the oil pressure sensor is also installed. I've got a permanent stain on my ceiling for forgetting that one on another project.
Old Oct 20, 2008 | 02:09 PM
Vette79C3's Avatar
Vette79C3
This is all I did and watch for pressure at the guage when priming.
Old Oct 20, 2008 | 02:17 PM
tfi racing's Avatar
tfi racing
I've used my DeWalt 18V cordless before,but a corded or air drill works better.You dont need high RPM,but you do need torque once the pump gets primed up so watch your knuckles!If you don't have a helper,just give the motor a quarter turn with a bar a few times so the oil gets to most of the passages.
Old Oct 20, 2008 | 05:56 PM
eastltd's Avatar
eastltd
I do not have a high speed drill and am wondering if an air ratchet is an acceptable replacement. thanks
Why don't you have a drill?
Old Oct 21, 2008 | 12:03 AM
DJordan442's Avatar
DJordan442
i do have a cheap black and decker 3/8 drill that have used for many many projects. its on its last legs so i think that i'll try it first - it might be fun to watch it go up in smoke
To Engine Priming
