Thermostat Housing?
Old Jan 9, 2002 | 10:38 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Thermostat Housing?
I'm getting ready to start putting my new heads and intake on, and the thought of putting my old nasty cast iron thermostat housing on my new shiny aluminum Edelbrock Performer, gags me!
I need some suggestions on what type of housing I should get? About the only thing I can find locally are some rather cheesy looking Mr. Gasket housings. Does anybody have any suggestions?
Old Jan 9, 2002 | 10:51 PM
Pedro'74's Avatar
Pedro'74
Default Re: Thermostat Housing? (Smokehouse69)
How about this one, Steve?
This is way out of my league, though. It costs ~ 70 bux! :eek:
I just bought a cast iron housing and painted it. Looks ok...
-Pedro
Old Jan 9, 2002 | 10:56 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: Thermostat Housing? (Pedro'74)
That's the one I'm using....quality stuff from Billett Accessories. Much better than the Mr.Gasket one it replaced.
Old Jan 9, 2002 | 11:25 PM
Paul L's Avatar
Paul L
Why not go with GM. I have often observed that people do not know that GM still sells parts for C3s.
Old Jan 10, 2002 | 04:11 PM
john's '81 mouse's Avatar
john's '81 mouse
Default Re: Thermostat Housing? (paul79)
Great suggestion by Paul.
See if you can get new aluminum housing from GM, then put the polishing wheel on your bench grinder and go to work. I polished my OEM housing last year and it came out looking pretty good.
I've heard many others say the Mr. Gasket chorme housing is junk, which will rust through in less than a year!
Old Jan 10, 2002 | 04:24 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
The cast iron housings may not be the prettiest (but with some silver paint, can be spiffed up), but they work. Stay away from the cheap chrome plated jobbies. They suck. The billet one's are really nice, but all things considered, are they neccessary?
Old Jan 10, 2002 | 05:24 PM
Corvettes White's Avatar
Corvettes White
Steve,
I found an factory aluminum style T-housing in a restoration Camaro catalogue. Looks great on my aluminum intake and looks like it was made that way.
George
Old Jan 10, 2002 | 05:30 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Thermostat Housing? (999)
been fightin with my mrgasjet one for months to get it to stop leaking just trashed it and put stock replacement one back on..no leaks mr gasket is junk.
Old Jan 10, 2002 | 06:05 PM
Steve Grodin's Avatar
Steve Grodin
Default Re: Thermostat Housing? (pats406nitrovette)
Mr. Gasket thermostat housing guaranteed to leak. :yesnod:
Old Jan 10, 2002 | 06:08 PM
Monkeywrench's Avatar
Monkeywrench
The summit Racing catalog had some anodized AL ones. Blue, red, yellow etc.. They were purdy...
Old Jan 10, 2002 | 06:13 PM
gearheadz's Avatar
gearheadz
Default Re: Thermostat Housing? (Monkeywrench)
The chrome aftermarket (i.e. MrG) work FINE as long as they're the version with the O-ring seal instead of a gasket. They don't even need any sealant. I've never had a problem with them.
Mark
Old Jan 10, 2002 | 08:19 PM
tsw71's Avatar
tsw71
Default Re: Thermostat Housing? (mdsmith)
Mark
I agree with Mark. I have been using this type for years with no problem. The condition of the intake's mounting surface has a lot to do with whether it leaks or not. Most aluminum intakes begin to pit and deterioate on this surface after a few years. If you use a small amount of sealer to fill in these pits, then it will seal fine with the O-ring type and gasket type.
To Thermostat Housing?
