shifter rattles
Old Oct 16, 2008 | 08:27 PM
painterman52's Avatar
painterman52
Default shifter rattles
I`ve got a hurst competition plus shifter that rattles quite a bit in 4th gear. If I pull on it it stops rattling. Can it be adjusted to make it stop?
Old Oct 17, 2008 | 08:50 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
the hurst competition plus shifter, bolts to the side of the transmission,
picking up and transmitting any vibration from the drive train.
The Orginal shifter mounts to the frame, generally speaking the Hurst is a tighter more prescion shifter, if you have vibration with a Hurst it most likely is coming from your drive train.
