Just finished getting the tilt/telescopic in my 69. Hooked up the battery and the buzzer won't stop buzzing. Even with the key in the on position or out of the ignition. Help!!
Jim
You are such a big help. Thank you so very much. Now, before I start pulling everything apart again, is there a quick temporary fix so I can drive the car in the next day to a show? Disconnect the buzzer wherever it is?
Hey! Mine started going off all the time and I was at a Corvette Club party!!! So I popped open the hood and on the driver's side there is a little module near the side (between fender and brake lines). It should be mounted to the side. Unplug one of those wires and it will stop. I think one is the horn and another the buzzer. They might be a total of four. I seem to remember a green, red, and black? It might have been green, but this was a while ago. I hope it helps!
Jim
Yes just unplug the pink/dark blue tracer from the horn relay as Young69 was talking about.
