Welding frame and brake hoses
Years ago up north, we used to hook welders to frozen underground water lines to thaw them out in sub freezing temps. But both leads were connected directly to the pipe and the pipe only warmed up in between the lead connections and of course it was always a metal pipe.
Maybe your brake fluid is some kind of super conductor.
see, the rear rubber line was not affected
was stick welding on the transmission crossmember with the ground on my drive shaft loop, which is welded to the rear cross member- toasted the rt. rear brakeline! caliper was not hot or any thing else. fixed up a ground site very close to the cross member & then was fine. I was perplexed as I had sticked welded many times over the years on frames & never had anything like this happen
Must be some kind'a electro-chemical reaction. I don't see a current path through those brakes lines to anything at lower potential. Must be something from the magnetic fields in the welding machine starting a chem reaction in the fluid. Did the welder use AC? I would expect DC straight polarity with a stick welder but cheap machines (buzz boxes) can use AC with the correct rod.Interesting and thx for post Gordon,
cardo0
cardo0
I've seen some guys fuse their door hinge bushings by welding on the door with the ground attached to the wrong side of hinge.
I wish I knew more about welding. I sell our tools (Lenox) to welding shops and distributers so I have the access to it just never persued it. I can seperate the steel just can't put it back together.
I agree with others who say this is an interesting occurence and look forward to the answer.
A welder buddy of mine has a stick/TIG machine and this is from what HE said over the last ten years.....he is a pro UNION welder of some decades experience.....
I know he used the full AC setting for TIG on aluminum....
but on iron/steel he uses a DC setting....well the transformers in his rig, being 220v house current input at 60 amps.....OR the output off any alternator being gas driven ....is a sine wave...
meaning the voltage/current/power alternates around the negative or ground lead......reverses polarity but does so smoothly and regularly like ripples on water it rises and falls, with a mid point being directly in between the peak and trough.....
so when you put a polarity on this AC signal, you have to run the power through a diode stack, which depending on which direction you want the diodes to 'point' you can make the resulting currents either positive or negative....soon as the diode sees the power go to the UNdesired direction, it is cut off......well, this cut off is very sharp, flat like hitting a solid wall, motion stops....
the resulting wave is nothing but a series of bumps and then a flat line to zero, then another bump....
what happens is what my buddy calls....HIGH FREQ.....short for frequency....that cutoff generates a LOT of RF energy being as it's very sharp....and VERY strong....and VERY close to the lines....which saw that on that mesh...and they fried from induction....
stick on in a microwave you don't beleive me.....not for long as that MW will destroy itself very fast.....
