Double off-set trailing arms?
Oct 19, 2008 | 12:26 PM
What is the difference between an off-set trailing arm and a double off-set trailing arm?
Oct 19, 2008 | 01:17 PM
The double offset moves in the spring mounting location also. It moves it in about 1 inch either side so if you are running a shortened spring with wide tires it helps the angle of the bolt.
Oct 19, 2008 | 01:27 PM
Learned something new today...Thanks Gordon
Oct 20, 2008 | 08:37 AM
Premium Supporting Vendor
Quote:
Originally Posted by
Gordonm
Most people that run the doubles use wide 15" or 16" tire and need them for additional clearance.
Oct 20, 2008 | 05:34 PM
if you run the double offset do you need to run a shorter spring?
Oct 21, 2008 | 02:33 AM
topless 77
Yes, i cut my spring 3/4 of an inch on each side to use with my double offset TA's from Van Steel.
15-16 inch wide tires??? holy cow. I'm barely fitting my 12" tires with maybe an inch of clearance to the frame.
Oct 21, 2008 | 09:31 AM
topless 77
Yes. We recommend 1" off each side as the spring bolt hole is moved in 1".
Oct 21, 2008 | 09:34 AM
68 NJConv 454
No not 15"/16" wide wheels, people using a wide tire on a 15"/16" rim
