Comp Cams 268H and vacuum level
Old Oct 20, 2008 | 12:35 PM
LannyL81's Avatar
LannyL81
Default Comp Cams 268H and vacuum level
I have this cam in my '81 with stock intake and E4ME carb, 882 heads with 2.02/1.6 valves, 74cc chamber, zero deck block, 2 valve relief pistons, stock crank, bored 0.030 over.
I have very low vacuum at idle (600rpm), about 15 - 17 at 1500 rpm or so. Is this just life with this cam or do I have a problem?
Headlights will not operate at idle, have to increase RPM to get them to move. Just replaced all hoses and checked for leaks....found none.
More details below..........................
Old Oct 20, 2008 | 01:51 PM
Vette79C3's Avatar
Vette79C3
I think you have a problem somewhere. I am running something similar to your build and no issues with vacuum including the headlights.
Old Oct 20, 2008 | 01:55 PM
Vampyre's Avatar
Vampyre
Something has to be leaking, it seems to be too low for 1500RPMs.
Maybe you have a cracked line, or one that is missing completely
Old Oct 20, 2008 | 02:05 PM
Vette79C3's Avatar
Vette79C3
Try and isloate the potential problem by eliminating the headlights from the equation and then maybe the emissions, etc. Something is definitely wrong. Was it like this prior to you replacing all the hoses? You should have that vacuum reading at idle and headlights should work.
Old Oct 20, 2008 | 02:11 PM
Bangkok Dean's Avatar
Bangkok Dean
I have the same cam with out a problem with my Lights. With all the parts in the vacume system it could be anything.
Old Oct 20, 2008 | 03:33 PM
LannyL81's Avatar
LannyL81
I measured the vacuum level at the intake vacuum port with all headlights and temp controls disconnected;
I have three of the five ports on the carb capped off.
Sounds like I have a leak somewhere, either in the carb or around the intake.
Guess its time to get the starter fluid out and go hunting......
Thanks for the replies.
Old Oct 20, 2008 | 03:41 PM
redman76's Avatar
redman76
St. Jude Donor '09
What do you use the starter fluid for? Just curious, may need that trick someday.
Old Oct 20, 2008 | 04:47 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I ran that cam in a 350 back when, and if memory serves correctly it pulled right around 15"@ 750 rpm.
Old Oct 20, 2008 | 07:16 PM
LannyL81's Avatar
LannyL81
Spraying starter fluid around possible vacuum leak areas will find the leak by a change in engine RPM when the starter fluid is drawn in. At least that is the method that I have used in the past.
Old Oct 20, 2008 | 07:27 PM
C3BB4SPD's Avatar
C3BB4SPD
It can be used to check for vacuum leaks at the intake manifold and carb gaskets. (Also works on vacuum modulators on automatic transmissions - which is where I would suggest the OP check) With the engine running, carefully spray it at the suspect area. If there is a leak the engine RPM will increase noticably. NOTE: When checking the carb gasket be sure that starting fluid doesn't get sucked into the throttle body opening, which will provide a false reading - indicating a leak where none exists.
Whoops - looks like Lanny beat me to it!
Old Oct 21, 2008 | 12:11 AM
redman76's Avatar
redman76
St. Jude Donor '09
Thanks. Never ceases to amaze me the stuff I learn on CF. That's a good tip to remember.
Old Oct 21, 2008 | 10:28 AM
baxsom's Avatar
baxsom
isolate everything first.
unplug and cap the headlights, tranny, brake booster, everything that draws engine vacuum.
check your vacuum reading at idle. that will give you an idea of what you should be working with. then start plugging systems back in. check headlights at each junction with a vacuum gauge. when you see a significant drop, the leak is close.
Old Oct 21, 2008 | 11:23 AM
LannyL81's Avatar
LannyL81
Right now the only vacuum lines connected are the one to the brake booster and the one to the PCV. Both of these are off the carb base. I am hoping that the single port vacuum fitting between the carb and the distributor is where the leak is. I am going to put either plumbing tape or pipe dope on it to seal it better and then check my vacuum level.
The current reading is just barely moving the needle on the vacuum gauge. I really do not want to replace the brake booster. Hope to get a look at it tonight.
Oh and this is a manual trans.
Old Oct 21, 2008 | 03:11 PM
baxsom's Avatar
baxsom
unless it is a valve not sealing issue this has to be it.
my bet is brake booster.
what happens to your gauge when you unhook the booster and cap it off.
check your one way valve.
also hook up a gauge, with the engine running watch the gauge when you press the brake pedal
It should dip as the pedal is depressed and return to the base reading. If it drops slowly, but returns, you have a blockage/collapse in the vac line. If it falls and does not return, you have a torn diaphram in the booster. Especially indicative of a torn diaphram is a hissing when the pedal is depressed
Old Oct 21, 2008 | 06:50 PM
LannyL81's Avatar
LannyL81
I will disconnected and cap-off the brake booster along with sealing the threads of the manifold vacuum fitting.
Having low, actually next to nothing vacuum at idle and then 15 - 17" Hg when I increase RPM is puzzling me. This is on a newly rebuilt engine with only a few hours of operating time on it. I sure hope its the brake booster rather than something with the engine.
Old Oct 22, 2008 | 03:08 PM
LannyL81's Avatar
LannyL81
Default Latest info
Measured vacuum at the intake manifold after putting teflon tape around the fitting. The brake booster, PCV and MAP sensor remained connected. (Did find a leak in the gauge hose).
Vacuum was about 10" at 600rpm, needle was not steady. Capped off brake booster - no difference, reconnected. Capping MAP caused idle to decrease and vacuum - reconnected. Did not cap PCV.
Adjusted idle mixture screws in and out with little if any difference in vacuum reading or RPM. Increased idle to about 700rpm, vacuum reading more steady, but still about 10". Hold engine at 1000rpm....15" Hg.
Seems that the engine either needs more air or less fuel. I am thinking that there is something wrong in the carb. May be the float level is too high as I have never been able to get any change with the idle mixture screws unless I either take one out or screw both all the way in. Is screw in = more air or less air? May be I should send this carb off and have it rebuilt at a shop that can wet flow it.
Comments???????????????????????
Old Oct 22, 2008 | 04:01 PM
DC3's Avatar
DC3
I chased a low vacuum reading at idle for a month or so before I figured out the problem was with my brand new vacuum gauge. It was reading at least 5" too low (9-10" at idle). After replacing the gauge with another new one, my readings improved to around 15" at idle which the mechanic that did my dyno tune said was about right for my engine and cam.
Here's a couple of vacuum related links that may help you:
http://www.therangerstation.com/Maga...acuumLeaks.htm
http://www.international-auto.com/fi...uum-gauges.cfm
Good luck.
DC
To Comp Cams 268H and vacuum level
Old Oct 23, 2008 | 12:21 PM
LannyL81's Avatar
LannyL81
Did a quick test of the vacuum gauge using my MightyVac...which is how I did find the leak in the gauge hose. Gauge appears to be working fine.
I am wondering if the vacuum port on the intake between the carb and distributor is true manifold vacuum, cause it appears that this is only the rear four cylinders if not just the rear two cylinders (7,8). Is this correct?
Old Oct 23, 2008 | 12:45 PM
C3 4ME's Avatar
C3 4ME
changing the timing on mine increased the vacumn at idle. I used to have about 12 at idle and now have about 17. Incidently, even at 12 the headlights worked just fine.
Old Oct 23, 2008 | 02:10 PM
Vette79C3's Avatar
Vette79C3
The vacuum tree between the carb and distributor on the intake is full manifold vacuum.
