Need help picking a VBP rear camber strut
As of right now, I have a new VBP smartstrut bracket installed and I was planning on re-using VBP poly struts I bought some time ago. This would create the following setup:
http://www.vbandp.com/detail.aspx?ID=632
The problem is that the threads on the rod are a bit too rusty for my liking and need to be re-cut. I probably would also replace the poly bushings as they only run $30. So my default option is to have the threads cleaned up by a machine shop and buy new bushings. Total rebuild cost maybe $80.
Question:
My other option is to just buy another pair of VBP rear camber struts, but unless I see a big benefit with the two models listed below, I am not planning on spending the money.
Model 1:
VBP "racing" struts for $250. Looks like the product below except for the "racing grade" spherical rod bearings.
http://www.vbandp.com/detail.aspx?ID=528
Model 2:
VBP HD camber struts for $190. Biggest advantage over what I haev right now seems to be the spherical rod ends.
http://www.vbandp.com/detail.aspx?ID=526
Does any of you have experiences with these camber struts? The car is being fully rebuilt right now and will be used for cruising, some road racing, some strip action.
Thanks, Michael
I thought of VBP smart struts as a replacement for the OEM struts with poly bushings and spoke to folks at shows that had them, but decided against the smart strut since it was not an original design and would lower my dual 2.5in exhaust under the diffential. The people who had the smart struts like them since the main advantage seems to be they lower the mounting point for the struts and reduce the angle for better camber control under the differential. Since I don't race the car, I decided to go with the super competition strut in the OEM location which would eliminate the exhaust pipe lowering issue.
I was told by Mid America that their super competition strut with the composite spherical bearing ends would stiffen the ride which they have but certainly not in a bad way and they don't squeak. They are very strong and hold the camber perfectly. All of my suspension changes over the last 25 years have transformed the ride and handling of C3 compared to the way it came from the factory. My car handles and drives like a modern sports car. You can dramatically improve any C3 vette with a host of modern updates to the suspension. I have been very happy with them. Hope that this info helps!
BTW, resist the urge to set the struts parallel to the 1/2 shafts for anything other than drag racing. Even with modern tires you still need some (neg) camber gain, and the most you can get with the VB&P bracket is still a bit less than that historically recommended by gurus such as Greenwood and Guldstrand.
