how to remove overspray
Old Oct 27, 2008 | 07:26 PM
Black804speed's Avatar
Black804speed
Default how to remove overspray
Guys,
My 2006 black Mitsbishi has gotten oversprayed enamel paint on it. What is the best way to get this off? Im not sure how to handle this problem with the modern paint finishes. Im not sure what kind of polish to use either or whether I should use my orbital polisher on it.
Old Oct 27, 2008 | 07:32 PM
ksbunting's Avatar
ksbunting
I have had good success removing slight overspray with the cleaning clay sold by Griot's Garage or some of the local auto stores.
If it is heavy overspray, you may want to ask a local body shop what they use for this purpose.
Go slow and be careful
Kurt
Old Oct 27, 2008 | 08:48 PM
TimAT's Avatar
TimAT
Clay bar. Your local auto paint shop will have that and the lube for it. Works great.
Old Oct 27, 2008 | 09:01 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Try WD40, sounds crazy, works great ! and won't harm your car paint.
69VETT
Old Oct 27, 2008 | 09:23 PM
Black804speed
Thanks guys. I'll try my clay bar on it first.
Old Oct 27, 2008 | 11:17 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Did the Bishsi have a recent wax job?
Old Oct 28, 2008 | 12:43 AM
blckslvr79's Avatar
blckslvr79
Easy Off oven cleaner! It'll take that over spray right off!
Old Oct 28, 2008 | 08:05 AM
1nicecorvette's Avatar
1nicecorvette
WOAH! just in case you do decide to try that last idea....DONT!!!
On the mustang boards someone asked about a fuel additive. the guy was just not a car guy but someone mentiond "put a bit of sugar in the tank and a dash of sand you wont have to worry bout it again". Well 3 days later the new thread was "why has my engine seized up after adding additive"?
When someone is as nieve about using a claybar for over spray and they are "desperate" to find a solution then sometimes we have to watch who and what exactly we offer for advice here cause the next posting will be, "how do i repaint the side of my car after using oven cleaner on overspray"! then wont you feel bad? personally i think he should of used brake fluid! (kidding) okay now write 100 times on the board i will not give out hurtfull suggestions anymore.
Old Oct 28, 2008 | 12:32 PM
blckslvr79's Avatar
blckslvr79
I will not give out hurtfull suggestions anymore.
etc...
etc...
etc...
It does work well to remove "everything" though!
Old Oct 28, 2008 | 06:08 PM
ngroat7007's Avatar
ngroat7007
... actually i dont know which smiley to use... thats just terrible! and can easily see it happening
To how to remove overspray
