smog diverter valve
Old Oct 30, 2008 | 08:50 AM
ripforrey's Avatar
ripforrey
Default smog diverter valve
I have a 76 in calif. so I need smog stuff. Does anyone know if a diverter valve from a 74 will work on a 76?
Old Oct 30, 2008 | 09:09 AM
fauxrs2's Avatar
fauxrs2
I dont know why not, I use a diverter valve from a 76 buick on my car. the real issue is the direction the pipes point.. mine point the wrong way forcing me to get creative in plumbing. but it otherwise works.
Old Oct 30, 2008 | 02:54 PM
ripforrey's Avatar
ripforrey
Thanks, that kind of what I thought. One end goes into injector pipe the other(?) I'm assuming the base of the carb.
Old Oct 30, 2008 | 07:00 PM
fauxrs2's Avatar
fauxrs2
no - there are two tubes on the back of the diverter valve - each one is plumbed to one of the check valves on the AIR rails. There is a vacuum connection as well.
Other than that vacuum connection there is no connection to the carb
To smog diverter valve
