Question for www.vansteel.com
You offer 350/450 lbs semi coil over dual adjust QA-1's My question is have you ever installed them on a car and tested them? I have called QA-1 and I can never get a good answer out of them as to why only light too long springs are offered
If your after the bigger spring rates, you can use the lower coilover arms with coilovers and than go big on the spring rate. I don't have the book in front of me now but I think we can put you in the 700# range. We may be able to bigger if you want with a little bit of mods to the lower a-arm and a different shock.
I'm trying to figure out where to put my money over the winter. I'm really thinking about the coil over kit and I would start with 700# and use shocks to control the front end. You can stop allot of front end compression just turning up the dual adjust to 18-20 on the compression side
Some of these older racing BBC Vettes tell me that they are running 1000# and smaller front tires than I have. Well I go and smoke them every race so they are either bad drivers or they just are not willing to try different things. I think that it is good to end up with a couple of inches of front wheel movement. Putting a 1000# spring and just a one inch sway and those old Vettes probably are not even getting an inch of movement.
BTW, those guys who still have huge sway bars with their very stiff springs have forgotten a basic concept of vehicle dynamics; that of needing less bar to adequately control roll when more spring is used, which facilitates a reduction of lateral weight transfer. Besides, as much as I like heavy spring rates, there is such a thing as being to stiffly sprung for a given surface.
Many believe that the goal is completely flat attitude under cornering loads, and they unwittingly go overboard trying to achieve that at the expense of cornering capacity. No, the goal of roll control is to maintain/manage suspension geometry within practical limits so that its movement in travel doesn't too significantly compromise grip. But, there is a crossover point where roll control beyond that required itself becomes a first order factor in compromising grip. That is why my philosophy is to run as stiffly sprung as conditions allow, subsequently using only the least amount of bar necessary to tame roll and, lastly, as a secondary fine tuning tool only in as much as such a crutch is required, rather than considering bar(s) as a primary component dictating everything else (which is IMHO working backwards).
edit - More bump is only slowing down travel so that there's not enough time for the front to compress down as far, but it's also speeding up weight transfer... something else you'll be free to dial back out with more spring.
