big block swap
Old Nov 2, 2008 | 09:26 AM
454vette's Avatar
454vette
Cruising
Default big block swap
Whoever said swapping a big block in a 73 vette was a pain wasn
t kidding! Ok, motor and trans are in, now I have to find the right crank pulley. The motor looks like it sits low in the frame. Maybe it's because I'm not familiar with big blocks. It looks like I'm going to need a two belt pulley that extends out 3 inches from the balancer. The pulley needs to be about 6 inches in diameter or smaller or it will hit the crossmember. Anyone have an idea of what I'm looking for?
Thanks for any help.
Steve K.
Old Nov 2, 2008 | 10:17 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Try reading this post:
http://forums.corvetteforum.com/show...681&highlight=
I think you're in for some sticker shock.
Old Nov 2, 2008 | 08:26 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you should have completed the pulleys and belts assemble before install.
It is a pain to get the BB configured correctly.
Now would be a good time to start a swearing Jar !
Here is a 1969 BB setup !
Old Nov 3, 2008 | 12:55 PM
sly vette's Avatar
sly vette
Hey.Someone stole your driver side shock!!!!
Sly
Old Nov 3, 2008 | 01:59 PM
bashcraft's Avatar
bashcraft
What accessories do you have?
Old Nov 3, 2008 | 06:47 PM
454vette's Avatar
454vette
Cruising
The only accessories are alternator and power steering which line up with water pump pulleys. The crank shaft pulley would work, but it has to be no more than 6" in diameter.
Thanks,
Steve K.
Old Nov 3, 2008 | 11:10 PM
joewill's Avatar
joewill
hree's a 70 setup, i just painted my exhaust manifolds and had this all tore apart, glad I took pics or my swear jar would have been overflowing! when you hit 50 the memory just starts to go.. among other things..
To big block swap
