Acting like Battery is dead
Old Nov 2, 2008 | 07:56 PM
ochsy's Avatar
ochsy
Default Acting like Battery is dead
My 74 L48 is all stock aand when you shut it off when warmed up and go to restart it, the car acts like the battery is half dead. Kind of like I all of a sudden have a high compression engine. It turns over very slowly but normally starts. I thought it was heat so I replaced the starter and added a heat shield to the starter and coated the exhaust pipe near the starter. The battery is new, the starter is new. Acts the same as when prior to changing anything.
Could it be that I didn't use the starter spacer that come with the new starter? What would happen with that makes the car hard to turn over when warm? Could the gears be binding and I need the spacer that was in the starter box? It never happens when cold, turns over great.
Ochsy
Old Nov 2, 2008 | 08:32 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Hot starter, do you have headers or a heat shield to protect the starter
Old Nov 2, 2008 | 09:50 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Could be a ground problem.
Old Nov 3, 2008 | 08:17 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I agree that you should check all your grounds and battery connections. Also a new battery that has sat on a store shelf can actually be bad. Don't dismiss that as a possibility.
Old Nov 3, 2008 | 08:31 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Ochsy
It could be that your timing is off. It's worth a check.
To Acting like Battery is dead
