junkyard scrounging
Old Jan 12, 2002 | 08:01 PM
honaker's Avatar
honaker
Default junkyard scrounging
I just finished my tour of 5 boneyards. Pickn's where slim. Found an alternator braket I was looking for. Now I can move the alternator to the passenger side of the car. Now, I won't have to remove it every time I check the power steering fluid.
Anyway, came across a couple of good looking heads. One was a set of 993's. Great shape, ready to be bolted on for $100. Could probably talk him done to $80. The other I don't about. They are casting number 14014416. Anybody got an idea? They looked great too, I just don't know anything about them.
:smash:
Old Jan 12, 2002 | 08:04 PM
e3pres's Avatar
e3pres
St. Jude Donor '08-'09
Default Re: junkyard scrounging (honaker)
1980-84 14014416 305 1.85 1.5 - 4 barrel
Those are 305 heads. Not worth having IMHO. Tiny valves.
Old Jan 12, 2002 | 08:08 PM
daily_driver's Avatar
daily_driver
Default Re: junkyard scrounging (e3pres)
hey what year do u have??
on my 76, the power steering cap comes straight out !!!
perhaps your setup is incorrect??
:confused:
Old Jan 12, 2002 | 08:55 PM
JB's Avatar
JB
St. Jude Contributor
Default Re: junkyard scrounging (daily_driver)
It sure doesn't come straight out on my '78. Real PITA of a place to put that thing--damned near impossible to check the fluid level.
JB
'78SA
Old Jan 12, 2002 | 09:04 PM
honaker's Avatar
honaker
The setting is correct. Just **** poor design on GM's part. Anyway, I took the new brackets from a 80's model GMC truck with a SB. The bracket will put the alternater where the AC should be. I don't have the AC in mine so, it just a simple swap. I'll add on to the wire that goes to the ALT and run it around the front to the other side. If you have AC in your car, this trick won't work. :smash:
Old Jan 12, 2002 | 09:05 PM
gdh's Avatar
gdh
Default Re: junkyard scrounging (JB)
Not that accessable on my 72 either.
Old Jan 12, 2002 | 09:13 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Mines easy. It's a 88 type that I mounted to the cross support. :yesnod:
Old Jan 12, 2002 | 09:15 PM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
JB
'78SA
Same with the 79. BTW, anybody have the correct part number for the alternator belt? I think mine is either incorrect or stretched out as the alternator can adjust out no further on the bracket.
Old Jan 12, 2002 | 11:36 PM
daily_driver
Default Re: junkyard scrounging (sharklover)
hmmmm
am i the only one that can remove the power steering cap here??
:lol: :lol: :lol: :lol: :lol:
:blueangel:
Old Jan 13, 2002 | 09:51 AM
KenSny's Avatar
KenSny
No, mine does not "hang up" on the belt, it comes out easy.....
Old Jan 13, 2002 | 10:08 AM
Ganey's Avatar
Ganey
hmmmm
:blueangel:
No. :cool:
Fixed mine in 77. Use a slightly longer PS belt. Cross this no. Gates 7365.
Old Jan 13, 2002 | 10:47 AM
killain's Avatar
killain
Oldtimer
I have a 79 L-48 and the PS cap is a little difficult, but it isn't that hard to get off?
Old Jan 13, 2002 | 10:53 AM
daily_driver
Default Re: junkyard scrounging (killain)
okay so my guess is that his belt might be a little shorter than??
or do as suggested and get a little longer belt then with the added angle you can get it out easily.
To junkyard scrounging
