VB and P Suspension
Old Nov 5, 2008 | 09:38 PM
dans68427's Avatar
dans68427
Cruising
Default VB and P Suspension
Does anyone have the fully adjustable front and rear suspension VB and P sells? If so is it worth putting on? Any pics? It is called the performance plus system.
Old Nov 5, 2008 | 10:26 PM
Gordonm's Avatar
Gordonm
Yes I do. It is worth it to me but not everyone. Fully adjustable is what I wanted.
Rear
Old Nov 5, 2008 | 11:09 PM
Kellys~hotrods's Avatar
Kellys~hotrods
Nice setup. Did it come with the outboard halfshaft hoops? Those are a good idea imo.
Old Nov 6, 2008 | 07:50 AM
Gordonm's Avatar
Gordonm
No they did not. I also have the Dragvettes 6 link setup. You can see more of it here.
Old Nov 6, 2008 | 07:43 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
I have the VBP composite up front along with their upper and lower A arms. I have the TRW spring in the rear adjusted by smart struts.
The ride below 30 mph is a little bouncy but it is very nice at highway speeds and this setup corners nearly as well as my C4. Very stable in the curves. 16 inch Sumitomos on TT2s.
Pay no attention to the exhaust......that's new now too............
Old Nov 6, 2008 | 08:04 PM
dans68427's Avatar
dans68427
Cruising
Got any pics of the front suspension and a side shot? Thanks
Old Nov 7, 2008 | 08:27 AM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
i have the kit but i still havent gotten around to installing the rear yet. here is a picture of my front setup though.
Old Nov 7, 2008 | 08:32 AM
7T3C3TTZ07's Avatar
7T3C3TTZ07
With the VB&P adjustable rear spring, can you run under car exhaust?
Old Nov 7, 2008 | 11:02 AM
Gordonm's Avatar
Gordonm
Yes you can. I just did not have mine on when the picture was taken.
Old Nov 7, 2008 | 12:00 PM
rosslato's Avatar
rosslato
Gordon get Jay to wipe down the fingerprints all over that bracket holding your spring.
Old Nov 7, 2008 | 12:30 PM
Gordonm's Avatar
Gordonm
You laugh at that, he did just that. When I got mine back they were all cleaned up!
Old Nov 7, 2008 | 04:20 PM
dans68427's Avatar
dans68427
Cruising
Thanks for the pics. I've been wanting that kit for a long time !
Old Nov 7, 2008 | 06:43 PM
LFZ's Avatar
LFZ
can you also install longer bolts on the front monospring to give you more ride height adjustability? (going lower)
Old Nov 7, 2008 | 07:27 PM
Gordonm's Avatar
Gordonm
If needed you can. I have never had mine at the limit of the bolts. It would be interesting to see how low I could go.
Old Nov 7, 2008 | 07:30 PM
rosslato's Avatar
rosslato
the bolts are plenty long enough. don't think u want to go any lower than the cokecan. me/GordonM and Jay are right around the same height w/the VB's monospring on the front end.
Old Nov 7, 2008 | 07:59 PM
vette427-sbc's Avatar
vette427-sbc
Technically you can, but I dont think you would really want to go much lower than the kit already allows you to
These are some pics when I installed my kit and some other things
http://s176.photobucket.com/albums/w...20Restoration/
To VB and P Suspension
