Collapsed steering column?
Old Nov 6, 2008 | 03:10 AM
cv67's Avatar
cv67
St. Jude Donor '05
Default Collapsed steering column?
Sorry not a Vette but still a chebby, figure they may be similar (67)
While installing the column tonight noticed my flange is about 5 inches further back than when I took it out yrs ago. COuld this have collapsed say if a body shop employee dropped it? If so can I pull it back out?
Just had it painted and cant afford to buy another one.
Old Nov 6, 2008 | 04:34 AM
cv67's Avatar
cv67
St. Jude Donor '05
Got it, the end was collapsed. Some ding dong thought they would be cute at some point. 2x4 and a BFH its coming back out.
Is this Ok to reuse ?
Old Nov 6, 2008 | 06:01 AM
Jim Shea's Avatar
Jim Shea
It is safe to use. There is a generous metal to metal overlap between the upper solid shaft and the tubular lower shaft that connects to the flexible coupling on the steering gear. It would have been a lot better if you had applied a constant force to pull the shaft back out rather than a hammer.
It is possible that you could have damaged the steering shaft bearings with the pounding. When you turn the steering wheel the steering could feel gritty if the ball bearings brinnelled the bearing races.
Jim
To Collapsed steering column?
