Vibration on 1978 vette
Old Nov 7, 2008 | 10:25 AM
78vettman's Avatar
78vettman
Default Vibration on 1978 vette
I have a 1978 vette with the L-82 and 4 speed manual trans. I have a vibration that happens in all gears (moving or stopped) at about 3500 RPM. The vibration goes away once I get over about 4000 RPM. The shifter vibrates and the car also will shake.
Any thoughts?
Old Nov 7, 2008 | 10:28 AM
Durango_Boy's Avatar
Durango_Boy
If it does it when you are in Neutral then you have ruled out wheel balance and anything after the transmission.
Has there been any work done to the car lately?
Old Nov 7, 2008 | 10:31 AM
...Roger...'s Avatar
...Roger...
Watch your fan as you run the rpms up and see if its vibrating or wobbling.
Old Nov 7, 2008 | 10:37 AM
78vettman's Avatar
78vettman
No work done to it lately, had this problem for some time and haven't had time to work on it. Just getting back started on it.
Old Nov 7, 2008 | 04:38 PM
blctalon's Avatar
blctalon
I have a 78 with 700r4 and 406 and have about the same problem as you except mine comes in hard at 3000rpms then seems to disappear. Everything on my engine and driveline is new and I've tried 3 different torque converters.
One thing I could of sworn made a difference was when I pulled my harmonic balancer to check it then reinstalled. The balancer itself turned out to be fine, but for some reason my vibration was gone for a while, it's back now. I'm thinking it's something in the accessories. Maybe a belt or fan or loose accessory. Check these areas and good luck.
Old Nov 7, 2008 | 06:36 PM
DaveP52462's Avatar
DaveP52462
Check the harmonic balancer.
Dave..
To Vibration on 1978 vette
