355ci build (opinions needed)
I just picked the block up from the machine shop and they had to bore it out .030. I'm dead set on not stroking it, so if thats your opinion, throw it out the window please
Here's the info:
010 4-bolt block bored .030
using stock crank, rods & flywheel, to be internally balanced
Speed Pro forged 3.4cc pistons
Brodix IK180 64 cc heads
Three deuce intake system: Offenhauser intake w/ Rochester 2g carbs
Hooker Super Comp 1 3/4" headers
ST10 close ratio tranny
3.55 rear gears
Compression ≈ 10.0:1 depending on head gasket
Now I wanted to go with the XR276HR Comp Cam, but I figured with the duration (224/230) it would give me too much overlap with a 110° LSA. The lift on it is .502/.510. Does anyone else think this is too big and I should step down to the XR270HR or am I just right?
Also, Brodix "recommends' fel pro's 1003 head gasket, which is .041" thick and would give me a 9.9:1 SCR. I was honestly hoping to bump this up above 10:1. Would it be a problem going thinner?
The goal was 400HP with more low to midrange power (a reason I'm considering the XR270HR).
Whatcha think!?!
But a couple of questions...
Why are you dead set against stroking? Is it just the added cost? (I'm not trying to convince you otherwise, just wondering.)
Why do you really want to get over 10:1? 9.9 or 10.0 has no practical difference... But anyway, if you wanted to get higher compression and use the 'correct' gasket, have you looked at domed pistons or milling the heads? (or just buying 58cc heads?)
Minor compression gains are very marginal to power gains
You can use a bigger roller cam @.050 than H-flat and it will still run nice.
buy the billet steel sleeved cam instead of a pot metal cam. Crane sells some nice street rollers with 112 lobe centers The 230/238 might be a good choice
Deck the block about 0.015" so pistons end up about 0.010" down in hole ... use GM gasket 10105117 or 14096405 (both = 5.8cc x 0.028") or Victor Reinz 5746 (5.4cc x 0.026") ... all 3 are composite & suited for use w/ alum. That is dual purpose approach ... optimizing quench while increasing scr.
If you have numbers-match block ... ensure shop will deck without cutting ID pad.
FYI ... all Erson sbc roller cams are billet steel & all come with friendly gear & often have nice price. Similarly ... GMPP has 2 or 3 rollers worth considering.
I've never heard of Erson cams, nor can I find them on google. You got a link jackson?
Header tubes that are correctly sized for your engine will help to scavenge exhaust gasses out of the cylinder.
If you go to too large of a primary tube, you lose the vacumming effect. So even though the pipe is larger, less exhaust gets out of the cylinder .
http://www.pbm-erson.com/store.php?catId=327
AFAIK ... erson bought merged w/ pbm a year or 2 back ... afaik still in carson city NV
