Quick Question
Old Nov 9, 2008 | 04:32 PM
Bigbuffer's Avatar
Bigbuffer
Default Quick Question
Hello to all.
I have a very simple question for the engine builders. What kind of balance did you use to weigh pistons and connecting rods? I am presently doing a 383 and according to the literature it needs to do this. I don't plan to race but I want to do it right since I am looking for something close to +/- 450hp.
Thx for any help and suggestion.
Old Nov 9, 2008 | 04:34 PM
sly vette's Avatar
sly vette
Don't waste your time..It's not needed on a street car IMO
Old Nov 9, 2008 | 04:44 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
The rods and pistons are usually somewhat close depending on who made them. But the crank can be all over the place. If you are installing lighter stuff than stock it's not a big deal unless you go crazy. If heavier than stock it can get into a mess. If it's an aftermarket crank, which most likely it is, they have no idea what parts you will put with it and if you're lucky they left it slightly *heavy* and it will be easy to balance. If not it may require mallory metal to get it right.
I'd go find a good shop to balance the assy. If the parts people tell you it needs to be done, then that means they made no effort to get it close by parts selection. You also need to know if it was designed to be internally or externally balanced like a stock 400 crank. Then you will need to have correct balancer and flywheel/flexplate.
JIM
Old Nov 9, 2008 | 05:20 PM
Bigbuffer's Avatar
Bigbuffer
Thx for the quick reply. I have bought an Eagle kit (forged crank, H rod, Speed Pro pistons etc...
Old Nov 9, 2008 | 05:48 PM
Grumpy 427's Avatar
Grumpy 427
They sell a balanced rotating assembly. My engine builder only charged me $150.00 to balance my last 454 we built.
To Quick Question
