cam options for 78 w/base engine
Old Nov 9, 2008 | 07:25 PM
mtsman's Avatar
mtsman
Cruising
Default cam options for 78 w/base engine
Hi. Newbie from central PA.
Long story short, my uncle bought a 78, 4 speed w/base engine (he says its not the L82).
He wants to get a slightly bigger cam w/ a little lope and do chain/springs/seals this winter. He asks me what I think about a 224/230, .480 SOLID lifter....? I am not well versed in this area. He says solid lifters will give it a better sound. I told him the build may not last as long.? He says he will only drive it 5k miles/year.
I said if he is doing the cam and valve seals he might as well do some heads. Another case of "while I'm in there...." He has 2.5" true duals w/x-pipe and magnaflows and likes the sound now.
First, can someone direct me to the base engine cam specs?
Next, I suspect he just wants an idle to 5500 cam with a little more LSA than stock to create a little lope. Can someone recommend a cam choice or two?
Second, I have read the vortec heads my be a direct bolt on. Is this true? Does a specific year work better or will any 96+ from a 350 do? Would we have to do some considerable gasket matching to get the 78 intake to line up with the vortec heads? Re-drilling required?
I am sure this has been discussed before but I just could not find it in a sticky.
Old Nov 9, 2008 | 09:17 PM
Durango_Boy's Avatar
Durango_Boy
The Vortec heads are in fact a direct bolt on. The only big issue is the intake bolt pattern is different and the original intake won't bolt on without some extensive modifications to the intake. It's usually easier to buy a Vortec specific intake from the after market.
The other thing to consider are the springs. Keep the cam lift under .420" or you'll need to do some work.
Old Nov 9, 2008 | 10:09 PM
PETE 79's Avatar
PETE 79
I would go with the Comp K12-210-2 218/218 duration @.050" .454/.454 lift. I would stay with a single pattern cam for better low end torque. BTW that part # comes with pretty much everything including the chain, springs, retainers, etc. Just no pushrods or rocker arms. I Installed this cam kit with vortec heads on a friends car with very good results.
Old Nov 10, 2008 | 08:23 AM
mtsman's Avatar
mtsman
Cruising
Originally Posted by Durango_Boy
The Vortec heads are in fact a direct bolt on. .... It's usually easier to buy a Vortec specific intake from the after market.
Thank you very much. Do you mean the factory springs on the vortec heads will float if subjected to more than .420? Or, if we changed the factory springs will the factory valve seals not allow for more lift than .420? I am kind of a newbie to this.
I assume the factory carburator is a Q-jet. Will the Q-jet and all accessories bolt right to a Vortec specific performer (or similar) ?
Old Nov 10, 2008 | 08:28 AM
Durango_Boy
Thank you very much. Do you mean the factory springs on the vortec heads will float if subjected to more than .420? Or, if we changed the factory springs will the factory valve seals allow for more lift than .420? I am kind of a newbie to this.
The stock Vortec springs will only be good to .420". However, you can install a spring up to about .470" give or take. Past that you'll have to do work to the heads for larger springs.
The heads have stock size and location accessory holes and the exhaust pattern is the same. The port shape is a little bit different but nothing you would notice.
The intake manifold choices might mean one or more of them lets you bolt on your stock carb. I'm just not sure about that and it has a lot to do with what brand and style you go with.
Old Nov 10, 2008 | 08:29 AM
mtsman's Avatar
mtsman
Cruising
Thank you Pete. I will check it out. I agree about the singe pattern. I just have no idea what the stock cam specs are so I did not know where to start. Can we reuse the pushrods? Do you have specific rockers you like or used on your friends car? What vortec specific intake did you use and did your Q-jet (assuming) and accessories fit right on?
Old Nov 10, 2008 | 03:45 PM
fauxrs2's Avatar
fauxrs2
Get comparison specs here
I've got the 78 L-48 amd L-82 cam specs on my web page. These are the specs provided in teh GM restoration package, so note that the duration numbers are different that the std. advertised or .050 specs. but it should give you a starting point.
Old Nov 10, 2008 | 03:57 PM
The Spark's Avatar
The Spark
I would contact your favorite cam company and tell them what you have and what you want. They will recommend a cam for you.
That's what I did on my 72 454 and have been happy with the choice.
A friend picked a cam for his 72 454 just by looking at the specs. His car idled so rough it was unpleasant to ride in. And it didn't develop enough vacuum at idle to raise the headlights or open the wiper door. You had to get out and raise them manually.
Not saying the guys here on CF don't know what they are talking about. They are probably much more knowledgable than me. I would just confirm whatever you choose by asking the company that makes the cam.
Old Nov 10, 2008 | 04:10 PM
Reggie Dunlop's Avatar
Reggie Dunlop
There really isn't much you can do with a low compression, single exhaust motor. Any cam that is "bigger" than the factory cam is going to be a compromise at some point in the RPM range. If you go 10 degrees bigger, low RPM performance will be degraded, but you will pick up a little on the top end. A general rule is that for every 10 degrees of increased duration @ 0.050 you need to have a compression ratio increase of about 1 point to retain good low speed response. You did not mention the exhaust, but if it is the factory 2 into 1 - 2 out of 1, more cam will net very little if anything.
Old Nov 10, 2008 | 05:02 PM
mtsman's Avatar
mtsman
Cruising
I've got the 78 L-48 amd L-82 cam specs on my web page. .
Thank you very much. I will check out. VERY nice wheels fauxrs2. Why the heck will my signature not appear,...??
Old Nov 10, 2008 | 05:09 PM
mtsman's Avatar
mtsman
Cruising
thank you. I understand the compression issue and agreee. In my first post I mentioned he now had 2.5" true duals, x-pipe, ending in magnaflows.
Kind of leaning toward a mild cam, vortec head/intake combo. I bet we could make better power and same or better MPG. I think vortec heads are 64-66cc while 78 L-48's are 75cc. If we go vortec, that should increase compression a little. Anyone done the calculations? Feedback?
Old Nov 10, 2008 | 05:40 PM
billla's Avatar
billla
St. Jude Donor '14
Just a note - the stock GMPP Vortecs are good to .475 lift per GM...but that is the absolute max. There are simple swaps that will push the lift out futher, but the stock Vortec flow levels out about about .475-.500...so there's not a lot there past that point.
You really don't want a solid lifter cam on the street - the "sound" he's referring to is the fact that solid lifters are made for high RPM engines, so they have a "lope" at idle. But for your engine they'd be a complete mismatch. If sound is more important than power, CompCams has "Thumpr" cams that have extreme overlap without crazy lift...so they're streetable, but they make less power (and less driveability and fuel economy) than the RIGHT cam for your engine.
A cam in the .450 lift range will do just fine with your stock heads; if you're heading for the Vortecs and can afford it, consider a retrofit roller - the dramatic increase in mid-range lift combined with the mid-range flow of the Vortecs will pay off with some incredible performance for the budget.
Old Nov 10, 2008 | 07:58 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Vortec Heads, a L-82 cam and a performer intake will be well matched and make good power with your exhaust and not break the bank.
Old Nov 10, 2008 | 08:33 PM
PETE 79's Avatar
PETE 79
You are better off just getting a new set of pushrods since they are not expensive. The rocker arms I installed on my friends car are Comp Pro Magnum 1.52 ratio part# 1301-16. Those will be coming back to me when he buys his own set of rockers. The intake manifold I used was a Weiand Stealth Air Strike dual plane manifold part#8502 with a 680cfm vacuum secondary Quick Fuel carb part# SS680VS.
Old Nov 10, 2008 | 10:34 PM
Glensgages's Avatar
Glensgages
Last year, a friend and fellow Forum-member wanted to do the cam/heads/intake swap on his stock L-48 '80 Corvette
http://forums.corvetteforum.com/c3-t...clearence.html
I'd guess he is a 3.55/3.73 gear-swap away from having a 13-second ride, and he seems very-happy with the results.
Old Nov 11, 2008 | 12:43 AM
jackson's Avatar
jackson
L48 base motor w/ stock bore
summit K1103 cam&lifter kit
vortec heads
felpro 1094 head gaskets
professional products 52007 intake manifold
static compression will be very close to 9.4:1, usually OE vortecs DO accept up to about .475", 1103 cam (about .443/.465) comfortably under that.
Old Nov 11, 2008 | 03:26 PM
BKbroiler's Avatar
BKbroiler
A couple more things about Vortec heads - You will need self-aligning rocker arms. You can get them cheap from GM Perf Parts. Your original pushrods will work. You'll need center bolt valve covers. You can use your Quadrajet with a Edelbrock intake for the Vortec heads with a drop base air cleaner for hood clearance.
To cam options for 78 w/base engine
Old Nov 11, 2008 | 03:55 PM
mtsman's Avatar
mtsman
Cruising
Wow. LOTS of great info. in there. Thank you.
Crab is from Scottdale! My uncle is from West Newton. Less than 10 miles from Scottdale! Unbelieveable. Do you think Crab would accept a call from my uncle to talk C3? Should I PM Crab?
Old Nov 11, 2008 | 04:00 PM
mtsman's Avatar
mtsman
Cruising
vortec heads
Thank you. I did not even know there was a performer knock-off. 9.4 is not too shabby.
Old Nov 11, 2008 | 04:08 PM
Glensgages's Avatar
Glensgages
I lived in Greensburg for 47 years until my liberation from Taxylvania in '06.....
I'd give Crabby a PM first..... if he hasn't put the '80 away for the Winter, or is busy shoveling snow, maybe he'll show you exactly what his set up looks-like, and/or let you hear it idle.
